Startup 'Pops and Crackles'
Someone on the UK forum has come to your rescue .... https://www.ftypeforums.co.uk/viewtopic.php?f=27&t=6370
A lot of very good(?) solutions, but I was hoping for maybe a software based solution to temporarily switch OFF and On the sound as needed(o.k., I am retired and getting lazy in my Old Age). The UK forum solution looks good for anyone so inclined to do that much work. I will pass on the towel extensions, and maybe "Free Bird" would work.
I guess for the time I will just keep garage doors closed? Most of my neighbors are not up when I am, so I can maybe blame the noise on passing construction trucks. still have a few of those around.
These solutions prove what I have been saying that this is the Best Jag forum. Always a solutions to ANY problem, even if it might not be used.
Thx gang.
Thx gang.
Iticip (06-26-2022)
How about a 12v vacuum pump spliced in with a y-connector to the vacuum hose. Would only require plugging into your cig lighter and using acc on for a while until it builds enough neg pressure for the rare occasions when you need quiet start. Would need more research on what pressure it needs to over come the spring tension and close the valves but definitely do-able DIY if noisy starts really annoy you. When you don’t need it don’t plug it in.
Viking_Quest
10-10-2023 12:12 PM
xpunjabiball3rx
04-18-2017 03:25 PM
