Stealth start-ups?
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Is there any solution (engine control brain flash, etc) to make cold startups less annoying? I love the fact that the car gets loud under hard acceleration, but I personally hate the obnoxious rev and growl on cold starts. I leave for work early in the morning and my daughter's room which is right over the garage and driveway takes the brunt of the howling F-Type V8 cold start. My neighbors certainly must think that I am a complete tool. Plus, there is no sneaking out of the office on the early side, since every single person with an office facing the parking lot knows exactly when I push the "START" button.
ANYWAY, is there a way to get a quiet first start? I know the car is capable of it, since the super-irritating "start/stop" fuel saver feature starts very quietly. Anybody found a way to have the startup sequence re-programmed to remove the growling rev run? I can't believe Jaguar wouldn't enable a way to turn this off so we can all be as juvenile or grown up as we want, when we want.
Suaro (01-27-2018)
I think there is very easily. This works on my V6S.
1. Get in the car and push the start button without putting your foot on the brake.
2. All the instruments will come to life as if the engine had started and will settle back down again.
3. Double check that Dynamic mode is no longer engaged from your last drive.
4. Push the start button again to turn off the ignition.
5. Now push the start button a 3rd time with your foot on the brake for a quiet first start.
Might work on the V8.
My V8S barks on the first start in the morning. No other time during the day does is bark when it starts. It doesn't sound like high revs either, just a loud, glorious bark. My neighbors probably don't like it, but I've conditioned them over the years with bikes, chainsaws and broken exhausts on other cars.
Mpowerr (03-26-2017)
We're dignified executives, and if we want to be able to come and go without fanfare, I might suggest we deserve it. =)
The "3rd time's a charm" thing didn't work for me... but I literally though Unhinged was going to make a joke about push starting it. LOL
My list would look like this:
1. Push the Start Button without putting your foot on the brake to start the Accessory Controls without starting the engine.
2. Double check that Dynamic Mode is no longer engaged from your last drive.
3. Double check that Active Exhaust is not enabled from your last drive.
4. Now, put your foot on the Brake and push the Start Button a 2nd time to start the engine with a quieter cold start.
As an additional help, I have definitely found that the morning start has some residual carry-over from how you last drove the car before parking for the evening. If you lead-footed your way home in dynamic mode for the last 5 miles and roared into your garage, it would seem this leaves excess residual fuel in the cylinders or exhaust that become explosive fodder for the next mornings' start. Conversely, if I have a leisurely drive home, in regular Drive mode and without racing the engine, much... the morning starts are more mellow...
I find its entirely dependent on how cold the engine is. Left overnight it is at its loudest (doesn't start in dynamic as that disengages after the car is left for a few hours).
Warm starts are a lot less noisy, and of course eco stop / start has no flaring of revs at all as was mentioned by the OP.
No combination of using the start button without putting my foot on the brake as described in posts above works for me - it flares the revs and makes a racket from cold starts whatever I do.
I found all the above works on my 2115 R, except #4.
https://www.jaguarforums.com/forum/f...xhaust-167276/
jaguny (03-26-2017)
Yes there is a way to get more control over the active exhaust. I posted a thread a couple weeks ago about this very subject which got hijacked in the very first reply to be about controlling the rear spoiler. Like ek993, UNHINGD's start-up sequence has no effect on my start-up noise because the cold start is controlled by the ECU. You need a controller to over ride that, which is in my previous post. Check out the thread and the first person that works with Steve Bisel at Forsa to fit the controller on the F Type would probably get a very nice discount. Plus it's not expensive any way.
That pump was eliminated on the 16+ models.
I do not believe my methodology could ever affect the exhaust valving. It merely eliminates the cold start-up over-revving. Since the valves are vacuum actuated, no controller will be able to hold the valves shut at start-up (no vacuum available until engine settles down to build it).
The controller is not for everyone in the same way removing the resonator and putting on straight pipes is not for everyone. It's just an inexpensive way to gain a little more control over what the exhaust does and when.
Yep, same here. No difference unfortunately. Oh well, I guess until somebody comes up with a software flash solution I will continue to be Mr. Loudstart. I do really think Jaguar overdid this. I used to have a twin turbo 335i BMW that gave a terrific rev run on startup but it was not even close to the "LOOK AT ME!" wail from my V8S F-Type.
![Icon Dance Cpatch](https://www.jaguarforums.com/forum/images/smilies/icon_dance-cpatch.gif)
Steve Youn (08-30-2016)
We've had threads on this before, and the procedures posted then and now don't work...
Per the old threads and my own experience, it seems to be totally dependent upon whether the engine is warm or cold and also the time since the last start. I've found nothing will tame the bark on a cold start or on a car that's not been started for a while. The second and subsequent starts right after a cold start or a start with an already warm engine will be much more muted.
I suspect some of these procedures were tested after doing a loud cold start, turning the engine off, following the steps listed and restarting. It seems to me to be a placebo... That restart would have been more muted whether you followed the steps or not...
