Steering wheel fluid reservoir
oh no, its drivable, but you know how you make a turn left or right and let the steering go and it goes back automatically to straight position, mine doesn’t but it works,
I suspect something was slightly bent (undetectable by eye) during the front end collision. Possibly the EPAS rack and pinion unit itself.
I wish, I bought the car in an auction 8months ago, fix pretty much everything under engine, is all put back together and is just this thing, getting annoying
As Unhing suggests, you have quite a few bent items. Looks like a pretty good impact. I can quickly see that the front crossmember is bent and the right side is curled in. The right (passenger) rail is shredded at the end. I assume all of these were replaced/ repaired? With the aluminum in these cars, you have to be careful who repairs it. Wrong welding or heat will destroy the tensile strength in the chassis/unibody etc..
As suggested, you should check to see if it will align properly, and/or have a B/S put it back on an EZ-Liner/Puller and see if all of the reference points and geometry line up to factory specs.(Given the damage I see in your photo.
Good luck!
DC
Good luck!
DC
everything is fixed properly and everything fit perfect, I don’t know if it was aligned properly but I did took it to a tire shop and aligned to specs I hope, I do recall now, one of my lower ball joints wouldn’t attached to the knuckle, I beat the crap out it, I even drilled a whole through to attached it, so I was able to move it, temporary in my garage to work on it, I forgot to replace that, you guys think that is the reason??, I believe it is but would like to get other opinions..., thanks
RA110623
03-17-2019 05:22 PM
mikewv100
03-02-2011 05:12 PM
