Sticky buttons.
During my research, I found this jaguar owner on YouTube that seems to have some success with make up remover pads. I’m going to give this a shot later today.
https://youtu.be/03olnY9xHUY
I’ve gathered from your past petrol post you are a scientist too. Yes aromatics are harsh.
SS4PK (06-19-2019)
Received 2,190 Likes
please don't do that to your car. The results look terrible. That woman has ruined her xj's interior. The new buttons and plastics no longer have the same soft-touch coatings. I'd recommend replacing in lieu of attempting to clean the coating off, just do a few pieces/buttons at a time (as your budget permits), eventually doing them all. There aren't that many pieces in our cars that need doing anyway.
SinF (10-17-2019)
I used liquid laundry soap(widow uses arm & hammer). Get an artist brush, dip it in the laundry soap, brush it onto the sticky surface, wait 5 to 10 minutes and then use a small cotton cloth to wipe off the gunk. Then get a damp cloth to wipe off any left overs. Let dry. Now if this old man could figure out the gps system!
PolkNole (08-19-2019)
I tried isopropanol and/or ethanol, worked okay.
Also so tried 20mL cooking oil with one drop of liquid dish soap in it, worked great.
I prefer the oil and soap mix to the isopropanol because it doesn’t evaporate while you try to work off the goop.
Just wipe it sparingly onto your buttons using a q-tip (ear cotton swab). Then use your fingernail to rub back and forth to help scrape off the sticky layer. Comes off easily. Wipe off excess goop and oil with clean paper towel. Then clean with damp paper towel to remove residual trace amounts of oil. Buttons will remain perfectly labeled (actually easier to read) and will feel great.
The following 2 users liked this post by Nedoerr:
David Meier (04-06-2020),
magredvet (06-24-2019)
#28
I have a 2015 F type that is a CPO vehicle. I have numerous interior areas that are sticky (l/r door triangular trim, l/r window switch and housing, interior door handles on the inside , steering wheel housing and all buttons, l/r side vent housing, interior f center section grab handle,some other dash and center console buttons). I went to the dealer who said not covered by CPO filed claim with Jag USA and to date declined, issue pending with Jaguar/BBB auto line. I think there is sufficient written documentation to support that the CPO warranty is supposed to be "bumper to bumper". Additionally, numerous automobile 3rd party entities also believe the CPO warranty is bumper to bumper but to date Jaguar USA maintains the warranty covers electric and mechanical issues only. They refence it being a limited warranty. If it is a warranty on top the original new vehicle warranty was that warranty also limited (abuse not included). Jag refuses to deny he claim in writing and also plays "hide the weeny" with the CPO covered/not covered list????????????
All that being said ,I have tried on my own per the info I have obtained on the forum; I have use goo gone, wd-40, 409, nail polish remover , water, paper towels.credit card, microcloths and a lot of elbow grease. You can remove the vast majority of this surface "mess" with a lot of tenacity and elbow grease. It will eventually loosen up and peel off like your skin peeling from over exposure to the sun. You iwll have to reapply the various chems and rub, rub, rub. Be careful with the credit card as on the door trim you can remove the underlying color and go straight to the black plastic(not desired). Unlike on the steering wheel where you really need to go to the slick black plastic base.
If a CPO warranty is important to you I would be very careful and read it (if you can get it) in detail prior to buying a vehicle. Right now, I am not too impressed with what they claim is a warranty which is on top of (means to me extends) the original new vehicle warranty.
#31
I would have to say yes as I have had it for 5 months. I initially thought it was all because of the detailing the dealer did and that it would go away with time/other cleaning by me. I had no idea this was an issue with Jaguar's over several models and years. I didn't even know about the Jaguar forum when I bought the car. I was locked onto a CPO warranty and believed everything people like Autotrader etc said about the Jaguar warranty.
#32
On the same subject has anyone else had a problem with the park button on the shifter? Luckily that's the only plastic in my interior that has gone sticky (the start / stop button is worn but I've a replacement on order) and when trying to clean it the "P" has smudged. I can't see the button available as a separate part so would have to replace the whole shifter!
#33
Received 3,209 Likes
For a long time we all thought as you that it was replace the whole shifter or nothing (mucho $) but forum member "addict" showed us a few months ago that the exact same button but as a Land Rover version was available as a separate part for cheap, see here for example: https://www.brit-car.co.uk/product.p..._sport_2014_on
Just get the LR part from your local JLR dealership, flip the old button out and press the new one in, 30 second job!
#35
if a cpo warranty is important to you i would be very careful and read it (if you can get it) in detail prior to buying a vehicle. Right now, i am not too impressed with what they claim is a warranty which is on top of (means to me extends) the original new vehicle warranty.
#36
Yep, very common for that button to be scratched or damaged, mine was from the start.
![](https://cimg3.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1038x1027/pbutton_1cef7bc73dc2d92ed2741f903dd8b3c730a23fa7.jpg)
Happiness is a new button
![](https://cimg8.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1500x2000/oldpbutton_c6b595b582c905dd1b2c07dbb7bcdc01d8947140.jpg)
This one was driving me nuts
![](https://cimg3.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1500x2000/newpbutton_04ff5a940941ab78e3d8fc92713da79bdad6ea04.jpg)
Much better
#38
#39
#40
