Sticky interior
I had an issue with my old Mercedes SL where vinyl door handles deteriorated and became sticky. The only permanent solution is to replace the part, but cleaning with rubbing alcohol kept it in check.
Assuming you already tried all usual cleaning methods, and you have an early F-type that have seen a lot of sun, this could be happening to you.
wow that's a surprise on a modern Jag...i thought sticky buttons only exist on Italians - lambo ferrari and maserati, all have that problem...the coating deteriorates from heat and UV and becomes sticky. Many tried to clean it with goo-gone and scrub the hell out of it. Use denatured alcohol works too but use it at your own risk...you might clean off the coating on top and lose the matte texture. There are a couple of companies out there that restore italian sticky buttons and parts, but i am not sure they have template for f type yet since it's pretty new
LobsterClaws (01-15-2018)
