STO N SHO hidden license plate bracket...
#142
Scrapping the muffler and resonator has little to no impact on emissions. Tossing the cat(s) does. But, plenty of states have roadside noise monitors as well. So, beware your mods. The F-Type is already precariously close to those decibel limits.
#143
Just ordered my STO N SHO bracket this morning. Its already in the mail and they included a check for 10% as I mentioned the forum. Should be here this week w
hich is great timing as I'm taking delivery of my IRR base 6 speed coupe on Saturday!! This looks like the perfect solution for mounting the front plate when needed. Thanks to the original post individual...MVP award to you!!!
buickfunnycar.com (07-27-2015)
#144
#145
99Gsp (07-27-2015)
#146
Thanks for the tip JgaXkr...my sales rep and I have emailed all morning about the bracket and he is aware I've ordered it and will receive it before he takes delivery from the port. I told him I wanted no holes drilled at all. I plan to drop the bracket off to them before they get the vehicle as an added measure that this is how the front plate will be mounted if I mount one at all.
#147
It takes 3 minutes with a flat blade screwdriver and 10mm wrench. While the directions are simple, it is possible to over-torque the mounting block, and I wouldn't trust the dealer "hole-driller" to do that.
The following 2 users liked this post by Foosh:
99Gsp (07-27-2015),
buickfunnycar.com (07-28-2015)
#149
#150
My MD dealer issued new tags and a printed registration card at the point of sale, which most dealers in this state do now. That's how I ended up with 4 holes in my bumper, which are fortunately now repaired, courtesy of the dealer.
#151
#152
![Thumbs up](https://www.jaguarforums.com/forum/images/icons/icon14.gif)
Just a tip . . . I wouldn't drop the Sto-n-Sho off at the dealer. Do it yourself!
![Icon Errrr](https://www.jaguarforums.com/forum/images/smilies/icon_errrr.gif)
#153
Also FYI, the mounting block can be installed upside down, and it won't latch, but the spring-loaded latching pin will still be on the correct (right) side.
I discovered this last week. When I originally received it and had the instructions, I mounted it correctly, but I took it off when I took my car in to have the bumper holes repaired. When I got the car back, I just slapped it back on without really looking. The correct mounting is with the two smaller extra holes (not used) facing the ground.
I spoke to Mike about it, and he said the original batch was adapted from the Z06 design, and the two extra holes were for that car. He's sold so many, he's ordered a new batch for the F-Type, which will only have the one mounting hole, and can be mounted either way with the pin on the right side.
#154
Plates and registration from my dealer too, except they entered the wrong plate # - off by one digit. I discovered this the following spring when I tried to have it inspected. Had to get new plates (turns out someone else was properly registered with the same plates as mine!) So check your registration to be sure it matches your plates!
#155
#156
#157
Where are you? Southern California perhaps? Mine was showing Friday dealer delivery, but I expect that PDI and prep will preclude Friday as delivery to me.
#158
Your dealer is in the distinct minority, and either got in trouble with MVA or simply refuses to participate in the point-of-sale registration process that virtually all other new vehicle dealers in the DMV (DC/MD/VA) do these days.
#159
#160
When I bought and flipped (sold) a SmartCar when they first came out, I had real tags on it when I drove it away.
