Storing CD's to the hard drive
Ok I have to admit this doesn't happen too often. I cant seem to figure out how to store cd's to the internal drive. There is no upload button on the My Music screen. Is this an option of the upgraded sound system or is there just certain cd's this option works for? If anyone can give me a quick answer that would be great.
The storing of cd’s is for any system. You can only store 10 cd’s.
It is not done in a “compressed” way as most system’s are so the quality is quite good. You do it under my music as I recall. I kept playing with it and it worked. It takes quite a wile to store a cd. I think it took about 10 minutes per disc.
It’s 6 AM here so I will get you more details this weekend if needed.
tlrominger (01-24-2014)
Im trying a normal audio CD. Guess its time to send an inquiry to my friendly Jaguar dealer. Unless I trip across the answer.
I had the Jaguar rep out to the house and it was one of the things he went over with us. He told me of the 10 cd’s max.
I can also use my I pod or I phone by plugging it into the slot in center council. That works the best for us as you can have your whole library and select what you want.
If you still having problems, PM me your phone # and I can go to the car on Sat. morning and call you and walk you through it step by step. Not a problem!
Scott
Scott
Scott
Scott
I got a micro USB key and put all my music on that, I plug it into the center console USB slot and I'm done. I can still stream wirelessly from the phone if I want and don't have to think about plugging it in. If I want to charge I have a cigarette charger with cables in the center console as well and it keeps my phone and tablets happy. Seemed a ton easier than ripping CDs, I get far more music, and when I want a change I just pull the USB key take it into the house and load a bunch of new MP3 files.
tlrominger (01-26-2014)
I found out yesterday that you have to remove any other iPod device from the USB port for Bluetooth streaming to work. I hope this helps.
swajames (01-26-2014)
My wife has an iPhone 5 and I have a Nokia 1020 (love the camera) both work fine. If I recall there are two ways to connect the phone from car to phone and from phone to car. One of the ways doesn't enable music streaming, don't remember which.
I found the same issue as tlrominger in my '13 Range Rover Sport. No streaming as long as my iPod was connected. If I unplugged the iPod it streams perfectly. Which begs the question as to why I even need it to stream if my iPod is already connected, because the music libraries are the same.
philwarner
09-05-2015 10:05 AM
Chet Ramnarain (bozzner)
09-03-2015 12:21 PM
