Strange noise when turn from steering column
Hi guys,
for some time now I've been hearing a strange noise that seems to come from the steering column. It sounds like a "tack", dry. It happens every now and then, especially when I turn all the steering wheel all the way and then turn it back. but it does not always manifest itself.
here it is heard in the twenty-third second
https://drive.google.com/file/d/1opfVCdXh_jYKqH9g5UgJyhUFBigZLB0f/view?usp=drivesdk
here it is heard in the tenth second
https://drive.google.com/file/d/15rKsxOiKsETW53sNvQr-fUIMrutDQU5S/view?usp=drivesdk
Has anyone had this strange noise?
Hi guys,
for some time now I've been hearing a strange noise that seems to come from the steering column. It sounds like a "tack", dry. It happens every now and then, especially snaptube vidmate when I turn all the steering wheel all the way and then turn it back. but it does not always manifest itself.
https://drive.google.com/file/d/1opf...w?usp=drivesdk
https://drive.google.com/file/d/15rK...w?usp=drivesdk
I went to my trusted mechanic and we inspected the front of the car. All silent blocks are fine and there are no strange games. Turning the steering shaft by hand instead (circled in red) it seems that the noise I hear is heard very slightly. Has anyone had any similar problems? Do you know of any steering box recalls?
Hi guys,
I also get a clunk noise in the back of my car (suspension?) on my first declined right-turn and first speed bump every day... Probably not related however.
I haven't solved my problem yet. The dealer wants me to give him the car because he thinks it's the steering gear box. It seems very strange to me...the car has 30,000 km.
I've been on the track and made some videos where you can hear the "tack" I hear when I turn the steering wheel. I have the problem when I turn the steering wheel about 90 degrees, both at low and high speed. When I'm stationary, if I turn the steering wheel I don't hear the noise.
https://drive.google.com/file/d/1gwN...w?usp=drivesdk
https://drive.google.com/file/d/1_DC...w?usp=drivesdk
https://drive.google.com/file/d/1b4d...w?usp=drivesdk
https://drive.google.com/file/d/12Sz...w?usp=drivesdk
https://drive.google.com/file/d/1P_j...w?usp=drivesdk
although the noise seems to come from inside the car, I believe it comes from outside. Lately I've heard the noise even when hitting a bump with the steering straight.
Can anyone help me?
thanks
Can anyone help me?
thanks
Hi, i have latest updates following some tests with my friend: I know that the noise comes from the front left part of the car and in particular from the top part.
When hear the noise, if I put it in reverse and I go a few meters back and hear the noise again, if I put it in first gear and go forward I hear the noise again and so on.
If I put my hand near the shock absorber, on the top where there is the cross symbol on the chassi, when I hear the noise I feel a vibration under my hand. believing it was a problem with the left shock absorber, I swapped the shock absorbers but the noise always comes from the left.
Before I realized that the noise was coming from the top, I thought it was to the stabilizer bar and I changed the left stabilizer bar link but no is this the problem.
If anyone can help me and knows a TSB for this defect it would be very helpful
marc4sgr
02-20-2010 08:20 AM
