Subwoofer feed behind seats
Hi all, behind the seats in my base model stereo (2015 V6S) I have the frame for a subwoofer and a mid range speaker. Only the midrange speaker is installed, the sub woofer is not installed. The connector has two wires out (to the mid range speaker), but 6 wires going in. I presume that 2 of the 4 remaining are for the feed to the subwoofers (if installed). Does anyone know if this is correct, which wires they are? and if they can be used to put into a line out converter, so I can amplify them for a sub enclosure?
thanks
thanks
The 4 wires are for a dual voice coil subwoofer ie a positive and neg for each voice coil. If you have the base 180 w system, your amplifier will not have any Channel on the end of those spare wires so no point taking a feed of them. In any case even if they did you wouldn’t take a feed off them. You should instead take a feed off the door woofers
Orchardbike (09-19-2022)
Damian D Lim
11-27-2016 11:27 AM
