Supercharger alignment pins
Received 3,226 Likes
https://www.mcmaster.com/dowel-pins/
Anything you order here you will get in no more than 1 to 3 days if you are in the US.
Following Information obtained from https://classicairheads.com/blog/202...r-replacement/
“The manual calls for “special tool” guide pins to be inserted into the cylinder head to guide the SC down into place on the gasket- these are just 50mmx M8x 1.25 headless bolts. I made some by cutting the heads of some headful ones.”
If you have the dimensions you can find replacement dowel pins here:
Yea I needed one to get the dimensions...
Following Information obtained from https://classicairheads.com/blog/2020/12/29/off-topic-jaguar-f-type-supercharger-re
moval-coolant-pipe-replacement-and-supercharger-coupler-replacement/
I already have a set of guide pins, that's not what I'm after. I need the dowels that locate the SC on the block.
