Supercharger Porting
I think your right Gasman2. We are getting to the upper limit maybe?
I do see only one guy breaking axles (He's broke two so far) and no one burning up transmissions. So we still have a way to go.
I don't know the limits of the E-diff either?
If the 8 speed starts giving troubles that has already been solved as the 8 speed comes in the Hell Cat and there are tons of upgraded internals out now because of these cars.
The following 2 users liked this post by Timbo:
Supersprint Sport Exhausts (11-27-2023),
Turko (11-27-2023)
800bhp…XF does 10.80@129 (1.64 60ft) with slicks and weight reduction DA 816ft. Nonetheless, amazing job and current #1 spot on dragy!
660bhp..VAP F-Type R does 10.98@127 (1.68 60ft) DA 1817ft with a roadster, full weight and 20” wheels wrapped in Michelin’s.
Arguably, the full weight F-Type roadster and stripped weight XF, weigh the same on scales.
The XF went 0.18sec faster with 2mph faster trap and an extra +140bhp!!?
Nonetheless, dyno’s can be misunderstood but 1/4mile trap speeds and times are black and white.
__________________
________________
Christopher Edgett
Technical Director
Velocity Automotive Performance Limited
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
Office Tel: (250) 485-5126
www.VelocityAP.com
Tuning@VelocityAP.com
![](https://www.jaguarforums.com/forum/signaturepics/sigpic170389_7.gif)
________________
Christopher Edgett
Technical Director
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
www.VelocityAP.com
WayneB (11-28-2023)
Some logic with numbers..
I did run a 10.56 at 132mph about 8 months ago I was having issues with the belt sliping when I ran the 10.8 at 129 got it fixed and it did 133mph then i added more fuel and some timing and now it should do 134-136. The car is full interiour minus the rear seats and front seat full interior I still have the radio,ac carpet everything car weights with me in it 4326pounds. stock weight is 4306 is the only xf made out of metal not the newer aluminum design. The rear reats don't weight that much maybe 15 pounds is all foam the front seat does weigh about 65 pounds but I did add about another 40weight back in I got a 3 gallon ice tank and a 5 gallon fuel tank. And I recently did a 6.7 60-130 full interior with an air compressor inside the truck. And yes I'm using slicks but that actually slows you down top end great for good launches but not good for top end speeds. I never dyno the car they want to much money for 2 dyno runs so I just go by other cars that make similar hp and weight similar. Do you think 6mph more =140hp? An remember that was 8 months ago now it should be higher
__________________
________________
Christopher Edgett
Technical Director
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
www.VelocityAP.com
________________
Christopher Edgett
Technical Director
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
www.VelocityAP.com
Ricky5.0s/c (11-28-2023)
#28
thank you sir. And yeah based on all the testing ive done it should trap 134-136 but like I Said I never dynoed the car I go by the mph and weight. Based on your experience what hp do you think my car is making based of the mph and weight? The fastest xfr only traps around 122-123 making about 660bhp a dodge hellcat traps 123-124 similar weight making 707hp a dodge redeye that has a demon engine in it does 127-128 making 800hp my friends bmw g80 fbo traps 137-138 he made 716awd hp and weights less than my car so I'm cufused🤔
#30
I live pretty close to Jokerz, so it'd be an easy drop off trip.
#31
I guess I'd like to do this as well, but curious if anyone has done this here. I know Dyno runs are expensive, but porting is $1400. The whole before/after math thing would be worth it. I'll send someone $100 if they do this, lol.
#32
The following 3 users liked this post by Gasman2:
#33
Hey Gasman good luck! I will be watching and hope you post back with what you think.
Considering a port job myself and with the bigger TVS2300 coming out I am torn between the two?
More money for the bigger blower and no numbers yet on power increases.
But as posted above you got to take any HP increase with a grain of salt for sure!
#34
The following 2 users liked this post by Gasman2:
JgaXkr (12-01-2023),
Supersprint Sport Exhausts (12-01-2023)
#35
Thanks for chiming in Stuart. My question, is this an injector max duty or the in tank pump not being able to keep up? I read another person has switched to a hellcat in take pump with some modification so that they could run full e85 because the in tank pump couldn't keep up, leading me to believe that the injectors still had some overhead if the pump was switched out.
Unfortunately the information about swapping the low pressure pump is only accurate for basic, basic applications. Like minor, minor states of tune, no pulleys etc. Yes, the fuel supply from the low pressure pumps is one issue to address, but that isn't the entire picture. There's other issues too.
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
![](https://www.jaguarforums.com/forum/signaturepics/sigpic147732_1.gif)
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
#36
We at VAP have done a LOT of research like Chris said. I shudder to even accurately quantify the cost in terms of staff & time that we've spent datalogging & researching this stuff. If I did we'd probably stop and call it quits LOL!
We have ported blowers. We have looked at all that sort of stuff. If it was possible and practical to do at this stage we would already be offering it but there's other limitations that we have to solve first. Once we have solved those, in terms of basic pump fuel, stock block options, I anticipate that the cost of the 2300 packages is going to be comparable or within close range of the cost of a ported, rebuilt, installed 1900. Similar or slightly better results but with much better efficiency.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
#37
#38
You know, I think I can accurately comment that this is at time, not far off from being true. As owners, we work a lot, don't really keep track of how or when. We just spent 3 days in Nashville working on software development for big turbo packages for the newer 4.0L Astons. Chris was on the dyno all day long, then working back at the hotel, we grab a quick meal and then working again until late trying to keep caught up and communicating with customers. Especially when travel & special projects are involved it can be all-encompassing.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
#39
Also how are they doing it, seeing as they're in the usa. Are they doing an exchange?
#40
