Supercharger Pulley Belt snapped
The following 2 users liked this post by Eurotoys:
(BMW)Doctor (04-19-2024),
Unhingd (03-02-2018)
I got the Eurotoys pulley and it didn't come with the HD belt, just the "ordinary duty" belt, Gates K080570. That's for the "Gen 1" stock pulley, for the "Gen 2" they sent me the Gates K080580 belt. I don't know when the V6S stock pulley changed from Gen 1 to Gen 2 but it was probably MY2015 to MY2016, seeing as I have a MY2015 and I needed the Gen 1 upgrade and unhingd has a MY2016 and he has the Gen 2 upgrade. Funny how unhingd reckons you should get the K080575HD belt, which I suspect is halfway in between in length of the 70 and 80 belts, so I'm guessing 1476 mm long. Despite the difference in length I guess that belt will be perfectly OK.
Make sure you get the correct pulley and belt, there are two different shapes of pulley and two different belt lengths, see post #3 in this thread: https://www.jaguarforums.com/forum/f...ecials-192638/
Mike, have you experienced any issues with breakage or excess wear with the standard duty belt? I suspect the more pliable standard duty belt would do a better job of avoiding slippage.
We supply an HD Belt with our Kit.
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
The following 2 users liked this post by Stuart@VelocityAP:
Andrew W (03-07-2018)
OP - this is correct. That part number also crosses to Delco, you can probably find one by calling your local O'Reilly or Advance Auto or something similar and get back on the road quickly.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
The only instance thus far that I have seen a belt issue was where the installing shop swapped the idler pulley over, but did not reinstall the washers (one behind, one in front) from the OEM idler. Consequently the idler was wobbling and the belt rode up on the edge of the crank pulley and sustained damage.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
#28
Received 3,249 Likes
Mike
#30
Can you clarify for what applications the "Gen 2" lower pulley would be used? My research shows the lower pulleys to be identical for all 2014-2017 F-Type model years. (I don't have access yet to the 2018 parts catalog).
#31
It's different for all models & years, several VIN splits. All kits are verified to VIN now and even that is not 100% due to the new Jaguar cataloging. We have had a handful that the VIN said they took 1 pulley, but were wrong.
Back when we did your car their was only 1.
Mike
buzzysingh
11-21-2019 10:51 PM
Luke5324
12-05-2015 01:50 PM
jar
01-19-2012 05:58 PM
