Suspension for base model is lacking!
My 2015 Chevy Volt with 150k miles in sport mode handles/hugs the road better than my 2015 Base Ftype with 60k miles.
This is just downright a disappointment when I pushed my Ftype on countryside roads after work today going for a spontaneous evening cruise.
I know it’s the base model, but no way in hell should a Chevy volt feel more planted and confident in corners.
Am I missing something?
Received 3,226 Likes
sov211 (04-05-2023)
Yup…the tires. As OzXFR says, if you have the Pirelli PZeros still on the car, the very best thing you can do is to ditch them and fit Michelins or Continentals. The handling will be transformed. There is nothing wrong with the suspension in the F-Types, but those Pirellis after some wear are terrible.
I think if I had a base, I would not only replace the tyres, I would go forged rims. The handling difference it makes over those heavy, heavy OEMs is incredible. And coupled with decent rubber (I went Supersports which are supposedly a little comfier) you can go up a few sizes without compromising ride quality. I have forged 21's with supersports, the car handles insanely well, but rides like it had with P zeros on OEM 19's.
I had test driven a base on 20's when the f type first came out and thought the ride was too hard, but with 60,000 miles on it your seats should be nice and soft, so I guess your problem is wheels and tyres.
Something else, I'm not sure where the battery on your volt is, but my wife just got a Mach E GT and the center of gravity is so low it feels really planted. I noticed I was almost more confident around corners in it, then our F-Type R or our GT500. So that may play a part as well, but as said above, if you have the P Zeros ditch them. I've always been a fan of Michelin Pilots but went with some Continental DWS+ on the F Type and couldn't be happier.
VroomForTwo (04-10-2023)
DWS and Road Force balancing
+1 on the Continental DWS... dry, wet snow and wear bars to keep track. My dealer competitively priced a set of four, plus I get "free" rotating/balancing for having bought a set. Rotation ever 5000 miles. I also had the tires Road Force balanced:
https://www.motorweek.org/features/g...orce_balancing
it’s more the issue of suspension bounces up and down like I’m in a speed boat on water even in dynamic…
not sure if the Volt feels more planted because it’s a hybrid that sits on top of a big battery in center of the cars undercarriage.
Bingo! the center of gravity thing I’m seeing making a difference.
Agree with everyone ...not sure if anyone said check the shocks.
Relative to an EV, center of gravity 100%. And a Volt weighs a little less at ~ 3500 lbs.it goes to. It may be more like a golf cars in other ways, but you cannot fault an EV in terms of weight distribution.
When I first got the new wheels and tyres on (with the weight reduction), it did feel that they werent necessarily in contact with the road all the time pushing it through corners at speed, it kind of felt as though it was skipping a bit. But that was really the back end not the front, the steering was much more nimble and perfectly direct. Once I got used to it, I found it heaps better, so essentially the front end is pointing exactly where I want it and then by the application of a bit of power the back end will skip into place, so you are effectively getting 4 wheel steering. Not sure about the base, but in the other models you dont get interference to power when the rear wheels slip a bit, so it is very controllable.
agree with checking your shocks. Shouldn’t happen. The suspension is obviously firm and will jar over small bumps in the road but I would not describe this as bouncing. One bump in the road shouldn’t cause multiple vertical undulations in your car.
sov211 (04-05-2023)
BlackPanther23 (04-05-2023)
Sounds to me like a suspension damping issue. Should be no "bouncing up and down". What year is your car, and did you buy it new? How many miles?
2015, 60k miles. Maybe I have too high expectations of the base? Given it’s a grand tourer…I had a Lexus ISF prior and that thing felt solid and glued to the road .
BlackPanther23 (04-13-2023)
I understand this thread is about "subjective" handling. But when we compare using "objective" criteria, a base model F-Type will outperform the Volt by a large margin.
On normal summer performance tires, the F-Type V6 base model will pull 0.90+ G on a 300 foot diameter skidpad and 0.97+ G on a standard 650 foot diameter highway off ramp type corne. The 300 foot skidpad is said to be similar to many of the tighter turns on typical racetracks. With faster or more open racetrack turn radius sometimes being 650 foot radius turns. (big oval tracks are obviously much larger radius)
The Volt is not capable of such performance, with a more normal 0.84 G's.
https://rechneronline.de/g-acceleration/curve.php
OzXFR (04-06-2023)
