Suspension broken by springs
Hi all. I do not know what the problem is but the front axle of my F-type R Coupe stays 2 cms high instead of 2 cms lower when installing Eibach springs. After removing and putting the springs several times, the right front suspension has broken. Has it happened to someone else?
The cost is 800€ but the worst part is that Eibach does not know why my car does not go down on the front axle!
[CITA = Chawumba; 2055049] wtf? Tal vez si puede proporcionar imágenes de lo que se ha roto puede hacernos más fácil ofrecer sugerencias. Nada viene a la mente de lo que ha descrito hasta ahora. [/ QUOTE]
There is nothing physically broken. Variable cushioning/suspension offers crazy values. The car is going well but failure of "dynamic driving modes" appears. I can not select any mode.
The way I understand it, they used a power tool to remove the strut and it spun the strut shaft, damaging the internals?
He said they were too aggressive taking things apart...
The car defaulted to some Extra Hard setting that was pretty nasty, I must say.
The shop that installed my VAP springs damaged a strut when removing it and I had this same warning until the strut was replaced. The car rode hard and bouncy during that time too.
By the way, did you change the 2 struts?
The truth is that I do not know what happened. I thought it would be a sensor thing but it was the strut. Something happens with my front axle or with Eibach because I have mounted 2 sets of springs and they have been high. So I have mounted and disassembled 4 times until the strut has broken ...
The front springs are shorter on the AWD model; if your car is AWD, is it possible they sent you RWD front springs?
