SVO Paint- how to protect
After hunting for a good used F type, I finally found a low mileage R 4 hrs from my home. I bought painter’s tape for delicate surfaces and was going to use that for the drive home to prevent chips and thinking I’d get a clear paint film put on it when I get home. The salesmen then told me to look at the pics again, it’s a satin SVO paint and is going into the body shop to have a scratch repaired on the passenger front fender otherwise the car is perfect. So can’t use painter’s tape and the clear wrap would ruin the satin look…. Besides being worried they won’t match the paint, any thoughts on how to protect the paint on the ride home and any recommendations for indoor car covers?
The best way to protect your paint while driving is to leave a large gap to the car in front. If there's nothing in front to throw up stones, stone chips are no longer an issue.
Get yourself a touch-up bottle from one of those companies that do the exact colour matched paints and drive your car like it's meant to be driven knowing you can repair any damage
Chuckster (07-06-2024)
I have satin SVO ethereal silver paint on my SVR. prior owner had partial PPF installed on contact points. if the dealer hadn't told me there was PPF I would have had no idea. I don't know exactly what brand/type of PPF it is but I'm sure there are films that will maintain the satin look because it's on mine and you can't even tell it's there
KJSJK71 (07-06-2024)
You can get matt PPF that should be barely detectable.
I have regular Expel on my shiny car and that is hard to see unless you look for the edges.
Does a good job on the front areas.
Actually had significant stone damage that was limited to the PPF.
That section of PPF was easily replaced.
Check out Suntek PPF - I think they do matt.
You are correct. I expect that, and I will drive it, unfortunately we have a lot of road construction in the San Antonio area so the debri is in the road, more than a typical road. So I’m tracking in the suggestion to leave space in front of me from others, or trailer it, I just wanted to give it a little extra level of protection and drive it .
Get yourself a touch-up bottle from one of those companies that do the exact colour matched paints and drive your car like it's meant to be driven knowing you can repair any damage![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
The benefits of having PPF far outweigh any possible perception of color change. Keep in mind, if you look hard enough, there is a difference in the paint appearance between plastic and metal painted surfaces, as well. You will drive with a greater sense of security knowing you have this protection applied.
I have Xpel on my front bumper cover, headlight lenses, and side view mirrors and have saved numerous paint chips/cracked lens. Just the same, become knowledgeable in fixing small paint damage. I have over the years [it's not difficult] and my car looks showroom new [almost, anyway].
