SVR Exhaust Cold Start
My 2017 SVR during cold start is loud but about 15 seconds it cuts out as if I turn the switch of Dynamic mode, which I don't. When I do drive away it can get very loud if I push it and cracks and pops like the best of them. I had a 2018 R that was about the same in crackles and pops but during cold start it kept loud and did not quiet down as my 2017 SVR is doing. Vacuum line issues or is this how it is? Just weird. Not sure if anyone has pic on what and where the vacuum lines are located as I would like to search them out. Thanks in advance.
Is it supposed to quiet down after 10 seconds or so even when I keep it in dynamic mode and when the revs are still higher than typical idle as it warms up? When I click dynamic on and off at this stage no difference. But Dynamic does make a difference when I am driving, and I get the louder crackles and pops as well. Just surprised it quiets down so much during cold start.
Another quick test could be to pull the fuse for the valves to see if it makes any impact on your cold starts.
Late to the party. My 2017 SVR does the same (I think!). Loud when I start it and remains loud until revs drop which takes a bit longer on a cold engine. If I pop it in reverse to back out of the driveway it quiets down
So if I'm out early I start it with garage door closed and pop it straight into reverse. Then give the door time to open (important step!!)
scm (10-26-2022)
RobMar (10-26-2022)
This is the normal (and intended)/pattern and my 2015 operates in exactly this way.
This is what my 19' does unless I put it right into Dynamic.
If fuse 15 is pulled, then the valves remain open no matter what?
yes. i removed the fuse temporarily but didn’t like it as i lost the ability to quiet down the car if coming home late so not to wake up the kids. Fuse went back in and I just pull the switch at start up…easy.
