Question. My SVR hood vent design permits considerable water into the engine compartment as a result of rain/washing. Is this a problem? Or not? (I realize the engine compartment gets exposed to water for all sorts of reasons, but I'm asking anyway.)
Background.
--The '17 SVR's hood vents are a more open design than my previous '15 F-Type R (Pic 1). Also, unlike the R's hood vents/louvers, the SVR's hood vents are located closer to the front of the car.
-- Strategically, the SVR has a swath of rubber placed immediately below each of the two hood vents (Pic 2), that cover the electronics on both shock towers. I assume the covers provide some protective function (including dust control and water drain-off), especially since they seem purposefully molded a particular way. Since I had a 2015 RWD, there may be other "protective" changes to the 2016+ AWD design as well, of which I am unaware.
--When I wash the car, I put non-stick paint tape over the hood vents. (I see this one coming: No, I'm not carrying a roll of tape to cover the vents if it rains, heh.)
--Today, I drove the car in the rain (first time in rain). When I arrived home, I opened the hood and saw considerable water on each rubber covering. But, I also saw the water found its way onto the charging terminal cover (red/black cover in Pic 2), which leads to my above question. (I've had hood vent/scoops in other vehicles, but their design allowed the channeling of rain/wash water.)
you worry too much. If this is how itwent out of factory, and you didn’t modify it, then it’s fine, Jag know what they’re doing
Thanks, Brava. Appreciate your input.
On worrying, I learned long ago to be choosy about what I worry about. Living in the Pacific Northwest as I do, directing unwanted water is usually one of them. ;-)
