SVR Wings??
SVR Wings??
Hi
Just starting to look at getting into an f-typeand i'm wondering i've seen a couple different svr's...some of them have the regular little wing that raises/lowers, and i've seen some with a larger fixed wing (I'm assuming its fixed). Are those aftermarket add on's, or were they options?
The SVR came stock with a larger "fixed wing" (the one with the end caps) but it's still also active and has a Vmax function, similar to DRS to stall the wing out for high speed runs (part of what allows it to have a higher speed than the R), there was no other factory option for SVR:
If it has the regular little wing then it's very likely not an SVR (can always double check the front power vents behind the front wheels to verify, that is also a quick visual distinction of the SVR:
I’ve never actually seen an SVR without the wing
The SVR does have the "fixed" rear wing. A delete was available as an option but it wasn't selected by most folks when ordering them new. Probably only 5% of folks.
There are several threads about adding an SVR wing to a non-SVR. It's entirely possible but the issue is sourcing all of the needed parts since it wasn't sold as a full assembly. Looking at $7k in parts due to low volume and carbon fiber.
gwng8 (05-14-2023)
I’m sure they’ve probably lowered the top speed to 186 then, not that that’s particularly a big deal!
