Swapping gauge faces
Hi guys
Am I the only one who prefers the first generation gauge face graphics
the newer cars with that red semi circle in the centre of the gauge face is just so out of place in not only an otherwise blue black light interior, but also just looks cheap
I want to buy a set of the first gen gauges and swap them over, anyone know if I can just swap the 2 gauges as ideally I want to retain the newer centre digital display
thede pics below actually show two different gauge faces and I'm not sure what model they are from - I prefer the first pic
Ahhhh I see now. You might want to change that first set of pictures as they are definitely the same gauges. But your second set of photos are different and I see what you mean.
Likely youd have to pull a cluster apart completely and potentially solder in the new gauge cluster pieces to get them to work.
i just found a cluster advertised off a wreck, and you're right it's all one piece = fuggheddabbouiiitt
let's just leave this thread up then to enjoy the fact jag actually have 3 different cluster designs, and have gone backyards since release - just like the trim finishes and front bumpers
