Switchable Active Exhaust
If you have the car in your possession, why don't you just pull the fuse and find out? I would do it myself, but my car doesn't arrive until late August.
I took delivery of a 2015 V6 Vert without the $1500 active exhaust option.
Can anyone confirm that pulling the fuse will indeed open up the flaps to enable active exhaust or did they use a completely different exhaust system?
I'm afraid that the vehicle sounds far too quiet and only makes decent noise above 5k RPM even when set in dynamic mode.
#30
Why don't all the people who have taken delivery of their cars, and want to know if this works simply pull the fuse? Takes all of 2 minutes to do.
If you have the active exhaust but don't have the switchable button in the cabin ($200 option) pulling the fuse will leave the valves open all the time.
If you don't have the active exhaust then you are out of luck, there are no valves to open as you don't have the exhaust in the first place.
#31
In the base car, switching to dynamic mode changes the shift points to higher revs, which makes it sound louder, but the exhaust system on the base car is "closed" all the time.
#32
If it's a base V6, there will be no fuse 43 to pull because it doesn't have active exhaust, which only comes on S and R models. In addition, for those cars the cockpit switch is a separate option, but if you don't have that switch on R and S models, switching to dynamic mode opens the exhaust, as does pulling fuse 43.
In the base car, switching to dynamic mode changes the shift points to higher revs, which makes it sound louder, but the exhaust system on the base car is "closed" all the time..
#33
That is not correct - if you do not have the switch, switching to dynamic mode does not open the exhaust valves.
#34
I beg to differ...the Active Sport Exhaust (which features active bypass valves which open during performance driving to allow exhaust gases to exit more directly for a deep,dramatic sound) while standard on the S and R models IS an option on the base F-Type...it's an additional $1500...and I added it to my car.
I do stand corrected on the switch. While I know it is standard on S and R models, I thought the switch was optional (except for the V8R), and dynamic mode was used to open the valves.
BTW, I had it on my C6 Z06, didn't particularly care for it, and I didn't want it on my base car. I'm happy with the sound of the non-valved, standard exhaust, and if I want loud I just use the right hand pedal to increase the revs. Even without, there's plenty of growl, along with popping and cracking on decel.
#35
I felt it was worth it's weight in gold in terms of added value so I wanted it for my car but then again,I'm used to loud cars...I have electric cut-outs on my '69 Z/28 with a 554hp race motor and 11:1-1 compression so trust me when I say it's loud and annoying,lol...and hopefully two guys will also think so when it crosses the auction block this Thursday at Mecum.
#36
#37
My F-Type is my new daily driver, and as much as I appreciate a pleasing exhaust sound and have it in the base car with no active exhaust, I'm over the too loud thing.
![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
#38
I'm sure it could be done, but it would no doubt cost more than the $1500 option price largely because of all the labor required to modify a finished car. In addition to std. exhaust removal and installation of the valved system, which should be fairly straightforward, there is wiring involved, but I'd bet there's an empty block in the fuse box for it.
Now whether a Jaguar dealer will do it is a different question, and I don't know the answer. Pick up the phone and call your service advisor, or better yet call advisors at several different dealers.
#39
I took a delivery of British Racing with camel leather last night, it is S 380hp V6.
I pulled out the fuse 43 this morning and the car did sound better, the active exhaust is always on, it is not noisy at all when you easy on the pedal, much better than my old C6 corvette which I had to put the fuse back because it is too noisy.
Hog
Hog
The following 5 users liked this post by hog4oc:
drphilgood (10-30-2022),
Foosh (08-16-2014),
jns2001 (01-01-2015),
pembroke (08-15-2014),
schraderade (08-15-2014)
#40
Hog
Hog
Sounds like to me a car can be equipped with active exhaust, but the switch is an option. Otherwise, why would one have to pull a fuse?
