Symposer Defeat
Symposer Defeat
If you're like me (don't feel bad if you're not: not many are) you don't like the sudden change when sound suddenly gets pumped into the cabin by the "symposer" system. I like to hear the engine sounds coming from the front and the exhaust sounds coming from the rear. The directionless noise that appears when I hit the right RPM and load is annoying to me.
Here's how to defeat it, and it takes only a few minutes and pennies worth of material.
Remove the engine top cover by pulling it straight upwards. There are four grommets that secure it.
Here's the fitting that connects the top of the symposer to the tube that pumps sound into the cabin. Remove the indicated bolt.
Wiggle that elbow as you pull upwards on it. It should come loose like this:
At this point, I rolled up some ensolite insulation left over from a sound-deadening project a couple of cars back and blocked the passage. If you don't have that, perhaps a cork could be carved to fit: Maybe from some Tattinger or a nice claret.
Reassemble and drive.
I'm probably going to try putting a ball valve into the hose, not because I think I'll ever want to re-enable it but so that I can from time to time as a reminder of why I don't like it.
The following 8 users liked this post by lizzardo:
De_Jag (10-17-2016),
George Smith (11-21-2022),
kb58 (08-30-2022),
MaximA (12-12-2016),
Pauluucho (09-27-2022),
and 3 others liked this post.
I'll refer to the diagram posted above by Tel:
The word "pump" was perhaps a poor choice. Channels sound? Directs sound? Piece #11 bolts to the intake manifold and is the source of the sound. The complex device at the bottom left (no number in the truncated diagram, but that's the "symposer") must condition the sound in some way, maybe muffling the mechanical sounds to give the desired quality.
Sound is channeled from the symposer through hose (#12) to the elbow shown in my photos (#1), through hose (#3) to #5, which bolts to the firewall. It is a small megaphone for the sound, which then resonates from behind the dash.
Parts #7 and 8 must be the switching mechanism. I don't think there is anything electrical, so it must be by manifold pressure/vacuum. It's been a while since I looked at all this carefully, but I don't recall any electrical connections.
I hope this helps. It really does take only a few minutes to try this out.
Frenchy (10-17-2016)
Received 3,259 Likes
Targeted frequency range is probably the same for both, in that they'd want to get rid of high-frequency mechanical noise and keep sounds in the same range as the exhaust. Certain conditions are easy enough to figure out. When I put my foot into it the car accelerates, and at a certain point the noise in the cabin jumps. The artificiality of that on/off behavior is possibly what annoys me the most.
One of the other boards here (XK?) has information about removing it, noting that it was anything but easy.
I don't think the weight is as significant as clutter. There's enough carp under the hood already.
I have no idea. I don't even understand how anyone thought it was a good idea.
"I know, let's add disembodied drone that switches on like a light switch!"
"Brilliant!"
"Brilliant!"
tallslenderguy (03-04-2021)
If you're still worried, some header-wrap material would surely be fire-safe. Something like this:
Thermo-Tec : Exhaust Insulating Wrap
I even have some, but didn't think about it for this use given the materials of the system upstream of the plug I added.
jfranks (12-22-2016)
