Tail Pipe Tip Cleaners
Not on an F type, but on my Audi A6 from new and now at 118k miles the tips still look like new.
The tips on my XJ although barely a year old again still look like new.
The only treatment I give them?
They get thoroughly washed every time I wash the car ( which is often ) EVERY time as part of my wash routine........
It really is that simple.
If they do need to be brought back at any time, I've used Autosol on others with great success
I use Eagle One Nevr-Dull to clean the pipes and all the chrome on my Harley. It's a merino wool impregnated with polish. Does a fantastic job.
Eagle One Nevr-Dull Wadding Polish
RickyJay52 (05-22-2015)
Mine get fairly sooty by Friday before the weekend wash.
However, I'm in dynamic mode and manually shifting virtually all of the time. There's a lot more popping and crackling when you drive it that way, which means more fuel dumped in by the ECU to create those lovely sounds.
mjm3457 (05-22-2015)
The extra fuel blown through for the popping will keep the valves cooler. If they switched to EPAS out of concern for the fuel economy, I don't understand how blowing the fuel through for the sound is consistent with that concern.
They'll last a lot longer running rich* than running lean. *Don't know this for certain yet before we get it on the dyno.
Cataclysmic (not a typo) Converter life could be shortened if the excess fuel dribbled into the system for the sound causes the cat to get too hot.
Why Did My Catalytic Converter Fail?
Hopefully, Jag didn't exceed the limit.
i use p21s polishing soap as a maintenance cleaner - it's a bit unique in being a hard waxy block that you wipe over with the supplied sponge applicator wet. can do it while the car is soaped down
and every now and then use optimum metal polish
P21S Polishing Soap
P21S Polishing Soap
P21S Polishing Soap
P21S Polishing Soap
Mine get a good sponge out with ph neutral car shampoo when I wash the car. If there is any soot that is stubborn, I wouldn't use anything more abrasive than Meguiars ScratchX.
Trials on many concours chrome bike exhausts has proven ScratchX to be the best for keeping the chrome good. I found wadding and metal/silver polishes too abrasive.
