Take off your engine cover!
Old 09-11-2016, 04:56 PM
Philly Single's Avatar
For those playing along at home...it weighs ~4.04 lbs
The following 2 users liked this post by Philly Single:
jaguny (10-10-2016), WJV (08-21-2018)
  #82
Old 09-11-2016, 06:46 PM
PolkNole's Avatar
...so if 900 of our readers remove their engine covers, we've just about removed the weight of an entire F-Type from the roads.
Burt Gummer (09-11-2016)
  #83
Old 09-11-2016, 09:20 PM
rbr's Avatar
rbr
rbr is offline
Took mine off... disappointed to see the cheap plastic crossover pipe in the cooling system. Was hoping it would have the metal one like the XKR.
  #84
Old 09-12-2016, 12:08 AM
lizzardo's Avatar
Depends on how may are V8s. Might need to be closer to 1000.
  #85
Old 10-09-2016, 08:07 PM
Dwelter's Avatar
on a related topic, I have not been pleased with the design of the hood vents. too obtrusive. Does anyone know if the hood vents from the SVR would retrofit onto the hood of my 2014 V8 S? I like the lower profile and believe they would breath easier. Thanks gentlemen.
Uncle Fishbits (09-15-2022)
  #86
Old 10-09-2016, 08:09 PM
Mbourne's Avatar
They won't fit. Different shape and different location on the hood.
Dwelter (10-09-2016)
  #87
Old 10-09-2016, 09:54 PM
OzXFR's Avatar
Received 3,212 Likes on 2,368 Posts
Back on topic - we had our first day of real spring weather here in Adelaide a couple of days ago, after just about the coldest and wettest start to spring in our history, so I whipped the engine cover off.
After a bit of a run yesterday I parked the car in the garage and immediately I felt a wave of heat coming off of the bonnet, so I felt the bonnet and it was much hotter than previously.
If the bonnet is radiating that much heat with the engine cover off I hate to think how much was being trapped by the cover before I removed it.
  #88
Old 10-10-2016, 09:29 AM
lizzardo's Avatar
If you still have your engine cover in place, next time you get home from a drive go back out to the car ten minutes after you park it, pop the hood, and feel the cover.
  #89
Old 10-11-2016, 10:51 PM
Frenchy's Avatar
After a bit of a run yesterday I parked the car in the garage and immediately I felt a wave of heat coming off of the bonnet, so I felt the bonnet and it was much hotter than previously. If the bonnet is radiating that much heat with the engine cover off I hate to think how much was being trapped by the cover before I removed it.
This contradicts Unhinged's measurements (see post #30): the hood surface after a drive, 125.6 degrees F with cover and 108 degrees without cover. He took these measurements to answer those who were concerned that the cover might serve as a protective heat shield for the hood paint.
Why then would OzXFR's hood give off a "wave of heat" when he removes the cover, but not when he leaves it on? Given Unhinged's measurements, one would expect the opposite.
  #90
Old 10-11-2016, 11:08 PM
OzXFR's Avatar
All I know is that was the first time I noticed a lot of heat coming off the bonnet. When I got out of the car I felt the heat immediately, which had never happened before. Maybe it was 100% due to the ambient temperature inside my garage being a bit higher than previously, who knows. My initial thought was that with the cover removed the heat that would otherwise be trapped by the cover was absorbed by the underside of the bonnet then radiated from the top of the bonnet. Doesn't matter to me, I will continue to run without the cover during spring & summer then consider putting it back on for winter.
  #91
Old 10-12-2016, 05:46 AM
Unhingd's Avatar
Received 4,661 Likes on 3,366 Posts
There could be a number of explanations, including that with cover off more heat is actually dissipating off the surface of the hood over a wider area (and therefore at a lower temperature). Without taking a large number of temperature readings across the entire surface of the hood, it's hard to tell what is going on. I had only measured the temp just above the engine.
  #92
Old 10-12-2016, 08:51 AM
DJS's Avatar
DJS
DJS is offline
Received 2,106 Likes on 1,406 Posts
If the engine is less hot without the cover, then that means more heat is leaving, presumably through the hood. So the hood being hotter isn't necessarily inconsistent with the engine being cooler.
A coworker points out that just because the top of the engine is cooler, that doesn't mean the engine internals are any cooler, as presumably the coolant temp isn't any different. I don't know enough to comment on that.
  #93
Old 10-12-2016, 09:23 AM
Frenchy's Avatar
DJS wrote: "The hood being hotter isn't necessarily inconsistent with the engine being cooler."
No, DJS, you missed my point entirely. I didn't say that the hood being hotter is inconsistent with the engine being cooler. I said that the hood being cooler (Unhinged's measurements) is inconsistent with the HOOD being hotter (OzXFR's observation). The HOOD can't be both cooler and hotter when the cover is removed.
  #94
Old 10-12-2016, 10:17 AM
DJS's Avatar
DJS
DJS is offline
I'd agree with that.
  #95
Old 10-12-2016, 10:39 AM
lizzardo's Avatar
Tell that to Schrödinger.
The following 2 users liked this post by lizzardo:
Stuart@VelocityAP (10-13-2016), Uncle Fishbits (09-15-2022)
  #96
Old 10-12-2016, 03:24 PM
Unhingd's Avatar
You can actually have more heat coming off the hood while the peak temperature is lower. With more circulation under the hood, the temperatures on average could be higher across the entirety of the hood (providing the temp differential for heat dissipation), while the localized temperature just over the engine is less. It would hurt my brain to try to put the calculations down on paper. I'll just rely on empirical observation: The paint ain't peelin' and the wrap ain't bubblin'.
  #97
Old 10-12-2016, 07:03 PM
Mbourne's Avatar
So the cat's alive!
  #98
Old 10-12-2016, 07:35 PM
The SVR does away with the cover altogether.
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
  #99
Old 10-12-2016, 08:04 PM
Unhingd's Avatar
Originally Posted by Mbourne
So the cat's alive!
lol
  #100
Old 10-12-2016, 08:31 PM
lizzardo's Avatar
So the cat's alive!
After 4.5 months in the body shop it is indeed! You never know until you open the box ...
Quick Reply: Take off your engine cover!
