Take off your engine cover!
Old 01-16-2017, 10:23 PM
zmoothg's Avatar
Just looked at the bottom of my cover and it has large imprint that says AWD. So I believe this cover is only for AWD F-Types.
  #142
Old 01-17-2017, 12:12 AM
Unhingd's Avatar
Received 4,661 Likes on 3,366 Posts
Originally Posted by OzXFR
..., but meh I took it off months ago and it's staying off!
+1.
  #143
Old 02-15-2017, 03:25 PM
NigelW's Avatar
I like the idea of dissipating heat quicker by removing the cover. I also like the idea that zmoothg had with the cover; cutting out sections and adding the mesh. Seems a reasonable compromise between cooler and ugly. I also want to keep the cover as is, so I need another one (V6).
I did a google quick search and found a few around from $90 US to $250, just wondering if anyone has purchased one, or has any suggestions on a good source that is not Jaguar dealer?
  #144
Old 02-15-2017, 03:45 PM
CRS 123's Avatar
Just curious, So w/o cover, some temp reduction and some faster cooling... so are there significant enough temp differences where engine performance etc can be measured?
CRS
  #145
Old 02-15-2017, 03:57 PM
NigelW's Avatar
CRS
Fair question.
For me I am not directly trying to get performance, more concerned that with the VAP crank pulley upgrade and assumed increase in heat with the SC, better cooler is a good thing. It may all be in just in my head and it will not make a difference.
  #146
Old 03-30-2017, 03:18 AM
BigDuke's Avatar
Does anyone here who has removed their engine cover also have the entire hood wrapped in PPF? I know that paint was a slight concern with the heat but I feel like the adhesive from the PPF would be quite vulnerable to the high amount of heat radiating from the top of the engine.
  #147
Old 03-30-2017, 03:32 AM
BigDuke's Avatar
Originally Posted by MaximA
I looked for a part number last night and couldnt find one, but a 3/4 in thick piece of dense yet pliable material. I checked Topix as well and couldnt find it the part but I didn't put in my VIN. Let me look again with the VIN entered and see if I can find some more information.
It may be for protection as the engine does move and the inter-cooler on the SVR is upgraded from the R.
Hello. Were you able to find a part number on the shield that is mounted under your hood?
  #148
Old 03-30-2017, 06:38 AM
Unhingd's Avatar
I have had the cover off for at least 12,000 miles and it has had no impact on the xPel.
  #149
Old 03-30-2017, 07:07 AM
Unhingd's Avatar
I believe this is the part number for the SVR insulation pad:
T4N2639
Not worth it for $420.
  #150
Old 03-30-2017, 08:59 AM
bwco's Avatar
T4N2639
I don't think that's it -- it's a different shape (bigger and rounded) compared to what's shown here: https://www.jaguarforums.com/forum/f...6/#post1575984
  #151
Old 03-30-2017, 11:16 AM
Unhingd's Avatar
Those parts sketches aren't always true to life.
  #152
Old 03-30-2017, 01:43 PM
bwco's Avatar
True, and it's definitely not worth $420 to find out..!
  #153
Old 03-30-2017, 02:20 PM
BigDuke's Avatar
I'm wondering if I could find a generic heat shield from another car and just cut out a piece and fix it to the hood.
  #154
Old 03-30-2017, 02:31 PM
Unhingd's Avatar
http://www.ebay.com/itm/like/2915982...&ul_noapp=true
BigDuke (03-30-2017)
  #155
Old 03-31-2017, 11:38 AM
Uncle Fishbits's Avatar
is it possible you won't know until you actually remove the xpel?
  #156
Old 03-31-2017, 11:59 AM
Unhingd's Avatar
I'll let you know in another 8 years.
  #157
Old 04-01-2017, 10:10 AM
lizzardo's Avatar
Here's where I normally start when looking for any kind of heat shielding:
COOL-IT Thermo-Tec ? Heat and sound insulating products
BigDuke (04-01-2017)
  #158
Old 04-01-2017, 10:20 AM
DPelletier's Avatar
Possible? yes, Likely? no......I'd bet good money that the paint can take more heat than the wrap can.
2 cents,
Dave
  #159
Old 04-01-2017, 08:35 PM
BigDuke's Avatar
This seems ideal to me. I just wonder if the adhesive backing will cause any damage to the paint.
Thermo-Tec Automotive - 24" x 36" ADHESIVE BACK
  #160
Old 04-02-2017, 09:43 AM
lizzardo's Avatar
I can't imagine it would. It's designed to protect painted surfaces. I havenb't used that exact product, but I've used a number of their others over the years and have always been satisfied. That's probably the one I'd use if I do remove or vent my engine cover.
Quick Reply: Take off your engine cover!
