Taking my F into the Dealership for Warranty work - Have Questions
I've had my 2005 F-Type S coupe for 5 months (purchased pre-owned) and am having the window surrounds replaced at the dealership in early April. The car has something like 17.5K miles on it currently. They are also replacing my rather scratched up orange Start/Stop button under warranty.
I am wondering what things I should be sure to have them check and/or update while they have it. Audio firmware (I have the 380 watt Meridian and have been quite pleased with it)? What are the 'must-have' updates and service bulletin items that I should be certain have been addressed?
Thanks.
Thanks.
Received 3,259 Likes
Does your engine rattle excessively? From the top/front of the supercharger?
Most noticeably at start up and cold idle?
Does it sometimes "clunk" when you shut it down?
If yes to all of these then the SC coupler / torsion isolator is shot and needs to be replaced, and it's a warranty fix for which there is a Technical Bulletin.
It's a fairly common problem on these cars, I had the fix done about a year ago but the rattle is now back again with a vengeance and I'm going to have it looked at by an independent workshop. If it is the same problem they will fix it properly this time.
My car is also a MY2015 V6S coupe.
Search on here for details of the problem and the Technical Bulletin.
Thanks.
Thanks.
quaker13
09-04-2011 05:09 PM
maddyn
07-11-2011 01:32 PM
DBR
10-09-2009 08:42 AM
