Tapa JRL Engines
Old 09-11-2022 | 10:38 PM
Iticip's Avatar
Default Tapa JRL Engines
So, my engine got water in it and needs to be replaced.
Insurance's first offer was to replace it with an LKQ used engine. Not sure how I feel about that.
Hoping them and the dealer can come to an agreement, but working on a plan B.
I cam across this remanufactured engine that seems to have some upgrades. Is anyone familiar with them or has any thoughts? Thanks.
https://www.ebay.com/itm/13414616589...3ABFBM-Mbu-OVg
Old 09-12-2022 | 01:48 PM
mikelr's Avatar
Well, sounds good on paper but I notice they have no feedback as a seller on Fleabay, so total unknown....
Iticip (09-12-2022)
Old 09-12-2022 | 03:10 PM
kb58's Avatar
I think their ad oversells what's being offered, as many of the "upgrades" are things that get done or replaced as part of any rebuild. Saying that "oversized" crank bearings are installed leads buyers to assume that they're better. No, the crank was refinished, which removes a small amount of material, requiring larger bearings to maintain the correct bearing clearance. They don't mention upgraded cooling pipes, but in their defense, it adds cost and is something easily added by the installer before dropping the engine in. That said, "Stage 2" does imply more than OEM goodness, and it's not there.
Using the word "Stage" in the description is pure Marketing because it lets buyers assume things like the engine making more than OEM power, yet they never state that. It may be a well-built engine, but don't assume that it's anything other than a normal rebuild which will make OEM power. As other said, with few or no reviews from other buyers, be careful.
BTW, do OEM Jag engine uses cylinder liners? If so, it negates another one of their "upgrade" bullet points.
Iticip (09-12-2022)
Old 09-16-2022 | 09:31 PM
Iticip's Avatar
Ok.. hopefully someone sees this.
The guy says he’ll put “SVR Cylinders” in it.. does the SVR actually have any different engine components? Or is it just software tuned?
Old 09-16-2022 | 09:40 PM
OzXFR's Avatar
Just a different tune, no such thing as "SVR cylinders".
Iticip (09-16-2022)
Old 09-16-2022 | 09:42 PM
Iticip's Avatar
Old 09-17-2022 | 12:52 AM
kb58's Avatar
That's the best kind of Marketing though, saying something that is technically true, while letting customers assume that it means something that it doesn't. If it's a well-built engine, why the need for the Marketing BS, just let the product speak for itself.
Iticip (09-17-2022)
Old 09-17-2022 | 01:06 AM
OzXFR's Avatar
Originally Posted by kb58
That's the best kind of Marketing though, saying something that is technically true (so they are not, in fact, lying), but it lets customers assume that it means something that it doesn't. If it's a well-built engine, why pull all the Marketing BS, just let the product speak for itself?
Yep, the ad linked in the first post seems to me to have a bit of marketing BS (well if not BS then hype) in it.
Take for example this line under "Upgraded Parts Installed":
"8 MM Timing Tensioners Better Oil Flow (Stock are 6.35 MM)"
Is that even a thing?
Yes the timing chains on the early AJ133 pre-2012 were 6.35mm pitch and the revised/upgraded chains post 2012 are 8 mm pitch, but I doubt if the tensioners measure the same as the chain pitch.
Most likely they really mean the remanned engine comes with the revised/upgraded timing chains, guides and tensioners (as it's virtually impossible to find new unused earlier ones these days) but if so why not say so rather than mention only the tensioners?
Iticip (09-17-2022)
Old 09-18-2022 | 07:49 PM
uncheel's Avatar
The effusive wording of the ebay listing made me twitchy. My gut reaction on the note about the larger tensioners was that they're starting with pre-2012 engines. That might not be the case, but I didn't see anything about where the engines came from - just that they target them for use in F-Types (that were all made after that design change).
I'd personally walk away, but, at a minimum, I'd insist on having a healthy independent warranty.
The following 2 users liked this post by uncheel:
EngineShop (01-08-2024), Iticip (09-18-2022)
Old 04-18-2023 | 01:20 AM
TAPA310's Avatar
SVR has a different piston tune and also has a larger supercharger I definitely understand the thread however it’s not just a tune I build & sell an average of 40 Engines a month without failure. It’s a total different build and believe it or not your local British garage or Land Rover Jaguar dealership uses our engines.
Old 04-18-2023 | 02:21 AM
OzXFR's Avatar
I accept that the SVR may have different pistons from the factory but I doubt it.
I don't accept that the SVR has a larger supercharger, all evidence points towards it having the exact same Eaton TVS R1900 supercharger as every other supercharged AJ133 ever built (excluding one-off ex-factory exotic builds if they exist).
TAPA310 (04-18-2023)
Old 01-09-2024 | 04:01 AM
I've removed two posts, banned one member and CLOSED the thread.
It has rapidly gone from a genuine member enquiry about Tapa Jaguar & Land Rover Engines to a sales pitch and then degenerated into a slanging match. Anyone wanting to promote or defend their products on the forum will only do so as a Sponsor or Vendor. Any member indulging in unsubstantiated personal verbal attacks on another member will not be tolerated.
Lycaon
02-27-2023 01:11 PM
Yulandop
01-09-2021 05:58 PM
aceofspade215
11-07-2011 10:10 PM
tilbury
10-14-2010 09:04 PM
estunum
XJ40 ( XJ81 )
03-25-2009 09:46 AM
Quick Reply: Tapa JRL Engines
