Tell me the negatives about the F-Type
#41
GerryJag,
I would take a look at rear wheel bearing and hub. After replacing a driver's side rear wheel bearing on my XKR convertible about a year ago, as I drove from the shop and got on the freeway and accelerated to the speed limit, I felt as if I had no control of the car, one of the scariest feelings I have ever experienced in an automobile. It felt as if the rear end of the car was coming up on the side of the front end. It would disappear below 55mph. I limped back to the shop and they discovered a damaged hub. Replaced and problem disappeared. I know it seems contrary to what you would think that the rear end would so severely affect the front end handling of the car, but it was frightening. Dealer wouldn't necessarily look at the rear rather trying to focus on front end problems.
#42
Go trade in your 435i for the ///M4 if you feel your steering is disconnected. I came from the E92 M3 and feel the 2015 F Type has every bit of steering feedback I need and its probably due to the fact they're both hydraulic steering. Your biggest negative will be the seating capacity
and I feel that manual transmissions are over rated.
![Icon Crackup](https://www.jaguarforums.com/forum/images/smilies/icon_crackup.gif)
#43
I recently drove a manual, and I honestly didn't notice any difference between it and the hydraulic steering on my 14. They felt equally "connected."
#44
True. On the other hand, I've seen at least a half-dozen reviews highly complimentary of the 16 F-Type's implementation of electric steering, all of whom have said they really got it right and noting a negligible or no difference.
I find all the controls in modern cars to be too light for my taste. Not that I need to wrestle with them, but I like the effort to be a little more deliberate.
#46
I have maybe 45 minutes total in the pre-16s, divided amongst 5 cars, and not recently. I was focusing on other aspects during the drives as well. I'm splitting hairs here, but going straight on the freeway I can't quite feel center if I'm steering with only a couple of fingertips. That's the level of my complaint, so feel free to dismiss it (and me) as you see fit :^)
#48
Thanks Guys, all input greatly appreciated
I still have the "old" original tires in the rear 16K miles, but ran over a nail about four (4) months back and replaced both front tires, dealer also aligned the car then. Yet the problem didn't go away. The front set has a mere 3K on them.
Interesting that the rear, e.g. the hub, could impact the front so much. I'm going to pick a "heavy" tech and go for a ride, hopefully I can scare him enough on the freeway so they take me seriously.
In my fuzzy memory I think I remember that I had a clicking or clunking noise that the dealer worked on in the rear of the car, and I think maybe that's when my front steering drift issues started.
#49
#50
Based on past experience, get your front axle tracking checked if you feel the front end is a bit vague about the straight ahead. All tracking specs come with a tolerance, if yours is at the outer end of the toe-out end of the tolerance, it's likely to feel vague in a straight line. If it feels fine straight ahead, but not that eager to turn in, its likely to be at the other - toe-in end if the tolerance.
#51
