To those that did their own pulley install on the V8
As the title states,
Those of you that did the install yourself, what tool/puller did you use to get the stock V8 pulley off? I borrowed a puller from a friend of mine which I believe is the one made by APR for Audis. It works/fits perfectly on the smaller pulley that I'm trying to install but doesn't fit around the larger factory pulley I'm trying to get off.
So where can I get/borrow/buy/steal a puller to get the stock pulley off.
Also Unhinged can you please remind me of the diameter of the stock pulley on the V8 so I can search for pullers.
Mpowerr (12-11-2016)
be used as an upgrade on Jaguars. That is, provided
the number and placement of grooves matches as well
as inner bore. Don't suppose your friend still has his
old one to measure/examine?
edit: 7 ribs
http://www.goapr.com/includes/img/pr..._side_ribs.jpg
That implies that a discarded stock Audi pulley might
edit: 7 ribs
edit: 7 ribs
Actually I came across a couple of pullers that were for the mini while I was searching, but no where was a diameter mentioned, I have emailed the manufacturers to see if they would fit a 66mm pulley but no response yet.
The pulleys are all the same from year to year. The upper SC pulley is 62mm on the V6 and 66mm on the V8.
