Thoughts on the V6AWD (vs RWD). Unnecessary Extra Weight?
The RWD is a very well balanced car and can be pushed hard by a skilled driver on dry and wet. A driver that is not highly skilled needs to maintain ample safety margins when the road condition is less than ideal.
AWD is the best option for both skilled and less-skilled drivers. It adds a tad of extra safety when you misjudge turns or push the car too hard in wet conditions. A skilled driver is faster in the twisties with an AWD but the car is a tad slower on straights.
It all depends on your driving style, road conditions and driving skills. The AWD is a safer bet
Since its a V6, I would personally go for lighter. I guess thats not surprising since I bought a V8 S because its lighter than an R AWD. I could be wrong but RWD is also rarer, so in 10 years I think RWD cars will sell for more than somewhat newer AWD cars.
Sure, RWD is just for drifting. Except that most of the fastest and most powerful offerings of today Mclaren 720S, Senna, and P1 and the Porsche 911 GT2 RS have RWD and they set the fastest drag times and track times. Its not just the extra weight that makes AWD less desirable, it's the increased drive line drag, and in the case of the F type they had to raise the engine 1.5" to fit AWD, which just can't be an advantage around corners.
Anyway to stay In thread, I think safety first to go faster. With a RWD Ftype, pay attention! Yes of course you are a skilled driver, but if you get some oil in the street, asfalt not good in a curve or same debris ..Even you are the best skilled driver with the RWD F-type you are lost, out of control! With the AWD probably you get in track. This is the reason I think awd are Always faster because you are always in safety and in a non stress situation , and you drive faster . NO AWD To gain 76 kg weiht gain ? No no thanks I will Always get the awd.
The risk aspect is truly a personal matter. I, for one, would have foregone airbags on the F-Type to save weight had that been possible. Half my fleet doesn’t have them. Safety just doesn’t factor into the consideration unless the vehicle is a veritable death trap. The driving experience for me is the primary consideration, though “go fast” comes in a close second.
The sport car you list above are rear engin or central engine, RWD Porsche can perform the fastest acceleration (better tha any awd) because of the big rear weight you get on the start (this is the 1st reason of the PORSCHE great acceleration), so doesnt need awd, the central engine sport cars are perfectly balanced , so the are fast in every situation. But a FRONT ENGINE SPORT CAR, with power above 400 HP, really need AWD. The question is the level of the power that you have to go AWD. I think about 400 hp, with a front engine car.
Dave
Boppo (12-11-2019)
#28
IMO, AWD is mostly to satisfy lawyers who have an intentionally superficial POV of driving safety so they can ignore the unintended consequences of their inputs.
Boppo (12-11-2019)
#30
#31
#32
Yes, but it is a doubled edged sword. Intervention more often decreases performance when you don't want it to. Electronic gizmos also fight you when you least need the gizmo designers thinking they are smarter than you, when you are in the car and they aren't. I would modify the above to "they can offer significant performance increases to beginner drivers, but more often create minor to severe performance decreases for the majority of drivers."
#33
#34
It is not always the case but when the ability to put down power earlier makes a difference, AWD is faster, especially on less than perfect tarmac
#35
I agree with you as far as ABS ESP etc. but the AWD system, as implemented on the F-Type - rear biased -, does allow experienced and capable drivers to push the car harder and stomp on the throttle earlier. As with every aspect of driving, the benefits are less with certain layouts but, for example, in high speed mountain climbs, AWD is faster. I tried it several times back to back, same driver and two stock F-Type R (2015 and 2016). Post tuning, the Delta in time advantage of the AWD grew.
#36
I didn't drive the V6 RWD back to back with the AWD, but I drove the V8S RWD back to back with the V6 RWD. In sections with multiple successive direction changes and no intervening straights, I could definitely feel the weight difference.
#37
#39
In addition to the tire variable, there's not really a choice between RWD and AWD. The choice is RWD or AWD + 175 lbs - HP + more money. If AWD was free it would be easier to compare.
#40
