Ticking Noise interior making me crazy
Hi All,
I have a weird ticking noise at the B pillar behind the passenger door at the small window. It is like a ticking noise that pops up when im driving , its there most of the time and sounds like a ticking metal piece. I have tried different things, taking out the cover of the trunk , taking down the plastic panels on the side but the sound is not going away. The car is just 4 years old and has 16k miles.
Does anyone have tips for me?
On the right side, the drivers side is the left side. It appears its coming from the area where the window is and i have tried to put pressure on the panels around it to see if the sound goes away but it doesnt. Could it be that the window is making the noise / something with the rubbers? Its like panels are creaking
Hi All,
DC
I have the coupe version btw.
the only thing i can come up with is get out all the trunk panels and than start driving around with the car to locate the sound.... haha i have tried everything what is possible before tearing down the car . Hope we find a solution...
The issue is the rubber seals along the hatch. I will try to get a picture and post it. The seal glue fails and when you drive at speed, it moves and makes that noise. It does sound like it comes from the spot you indicated.
I will try to get some pics for you to demonstrate. You can use 3M adhesive and re-seal it, and it should go away. This is the most likely cause anyway. I was wrong once though
DC
DC
Jaguar1611 (12-08-2020)
DC
DC
Really? This would be great. I can try it.. i really cant imagine that the ticking sound comes from rubber seals haha! I am really hoping this would solve the issue , looking forward to your post! Much appreciated
Mbourne (12-07-2020)
I will take it our for a drive and let you know if it is solved! If so i owe you one....
