Timing chain upgrade
I'm replacing head gaskets on my recently acquired 2014 F-type 3.0 S. I have read about all the timing chain issues, but is there a timing chain upgrade available to a wider version for this engine?
If so, I'm guessing it has to be quite expensive considering what all needs to be changed and that it's not a high-volume item.
I don't plan to use this sweetheart as an everyday driver. nor will it ever go cross country. Mostly Sunday trips to the lake and once or twice weekly to the golf course. So, I'm guessing the standard chain will suffice. I didn't purchase it for performance, just the looks. A convertible F-type looks really sharp, IMHO.
Received 2,637 Likes
Received 3,217 Likes
JLR updated/changed the timing gear (chains, guides, tensioners, sprockets etc) on the V8 in 2012 and when the V6 came out the same year it also had the updated timing gear. So every V6 F-Type ever made has the updated gear which is far less problematic than the old V8 gear, and there is no need to go to the expense of renewing the timing gear on the V6 unless or until it really needs it which is quite rare these days.
