Tiny stone chip in grille chrome - suggestions?
hi,
Just got back from 10 days camping in the south west of Victoria, along arguably one of the best stretches of coastal road in the country - The Great Ocean Road.
Managed to squeeze in 7 runs along my favorite 33km hill climb (see below) during the week, and recorded 1.23g around one of the hairpins on the G Meter (have you all played with that yet?).
Alas, after I got home and washed the car, I found a small but noticeable (to me) chip in the chrome of my lower right grille - perhaps 3mm across (1/8" for you US guys).
Any thoughts on the best way to deal with it?
OzRisk (04-07-2015)
Adding to what lhoboy is saying, there are a number of chrome-like paint products out there. Some better than others. You'll likely have to settle for a spray can rather than a touch-up kit with integral brush in cap. They may exist, but I haven't seen a touch-up kit offered in chrome.
If you happen to find a touch-up kit in chrome, note that the built-in brush is not the brush you would want to use. I use a very fine horse hair brush (Size "00"), and dip only the very tip (not more than 1mm) of the brush into a small cup of paint (which is first filled by gently spraying a little paint into the cup).
Adding paint from a spray can can be done without mess--just press gently on the paint can nozzle (which is first poked through a paper towel covering the cup to help ensure paint doesn't fly all over the place) into the cup.
With my double-ought brush tipped then with a small drop of paint, I "nudge" the paint into the various recesses of the chip. Hopefully, the chip has a minimum of sharp edges to it. Still, you'll likely have to make several passes, as the paint dries rather quickly in such a small area. Eventually though, your repaired chip should be level enough pass your inspection test. Not as perfect as tape and spray, but in such a small area, certainly acceptable.
Last edited by deltagroup; 04-07-2015 at 12:33 PM. Reason: Sounds like you had some trip!
OzRisk (04-07-2015)
Of course, non-metallic, Polaris white is the probably the easiest color on which to achieve nearly-invisible, small rock chip repairs. I'm having trouble finding the places I touched up.
OzRisk (04-07-2015)
As an aside, I was very happy to find such a very tiny brush in the Jaguar touch-up kit I purchased in Polaris White. I used it last weekend to repair 3 very tiny rock chips in the lower rocker forward of the rear fender. It's the only kit I've ever seen with such a perfectly-sized brush, and all it took was the tiniest drop of paint with a very light touch.
OzRisk (04-07-2015)
Thanks for the tip. I went in and ordered one today (not for the chrome - for the stratus grey - I have a couple of tiny chips in the drivers door frame that have been annoying me too). It will be here on Friday.
Oz if you want to outsource I have used these guys with great success in the past, quite reasonably priced and they do a good job. Also perform Magic with kerbside rash on wheels.
Mobile Bumper Repairs, Chips & Scratches, Exterior Car Detailing - Touch Up Guys
OzRisk (04-08-2015)
While I have used companies like Andrew recommended in the past and had them to a pretty good job, the type of little chips I'm talking about are 5-second repairs at most for a very good result.
In those cases, it's not worth the trouble or even nominal expense, and the JLR kit is the right tool for that job.
Ipc838
09-13-2015 03:27 PM
doctordeuce
09-12-2015 08:30 AM
1964Daimler
09-09-2015 11:28 AM
