Tire Pressure Monitor / View vehicle status
Can anybody else click on the view vehicle status option in the menu screen? Its completely greyed out on my car and I can never get into it. Trying to find where I can view the exact psi of each tire. I got a flat tire yesterday and got it replaced today but got the low tire pressure alert again. I brought it back to dealer where I'm at now but want to be able to monitor exact psi of tires just can't find out where and service guys have no clue.
You have to be in park if I recall correctly. If that doesn't work try it after turning on the car without turning on the engine (press the start button without pressing the Brakepedal)
But I don't know why my v8s convertible doesn't show tire pressure on that screen. I think it's only an r option
Thanks turning engine off did actually let me get into the vehicle status menu. Sadly nothing useful at all in it but in case I forget my VIN# i now know an overly complicated way to view it. I really can't believe its so difficult to view a current psi reading for all tires. This is a super basic feature every low end car has these days.
You and I have very similar cars and I have looked up and down on mine and cannot view the tire pressures on the display either. All my Chevy company pickups have this capability (while driving) and it would be nice to have on the Jag. I have also not found any documentation anywhere that states which cars have it or how to display the information. Reading other comments, it sounds logical that it may only be available on the R’s or 2015’s.
I will ask my dealer on the next service if a simple software update will add it, although I hope that will not be anytime soon.
I've said this before here, but I've also had the TPMS read-out feature on other cars, and never found it useful--never bothered looking at it. I'm exclusively concerned about cold tire pressures, which are the only accurate ones. I also check them regularly with a high-quality tire gauge, which is also far more accurate than the TPMS sensors.
Depends on what type of sensors are in the wheels. On my Porsches, the TPMS gives you two readings
1- pressure
2. Temperature corrected pressure
It then has a display giving you + or - and how many pounds needed.
The TPMS is very accurate and what Porsche recommends you work off of.
Have no idea why the Jag sensors are capable of and find it nuts you can not access the readings. At least in my car I have not figured out how to.
Walt
1- pressure
Walt
Foosh (11-15-2014)
1- pressure
Walt
1- pressure
Walt
But yeah I would guess it's a model year thing.
Aus V8S
11-13-2015 11:01 AM
