Tire wear and CPO
Hello all,
does anyone know the exact measure at which point Jaguar has to replace tires for CPO?
I have my CPO worksheet and my rear tires were evaluated at 4/32" and listed as "have to be replaced", The problem is that they replaced them with 5/32" tires. Considering the quality of those Pirelli, it means I have to replace the tires now, 3 weeks after buying the car.
Now someone else tells me that they can't CPO a car with tires below 6/32"
Anyone has insight on this?
Hello all,
So, am I to understand that they put on used tires with 5/32" tread prior to delivery of your car as a CPO? My CPO came with two new rear tires that were installed as part of the CPO process. Could it be that they didn't replace the tires, and there is just some difference in the measurements (i.e. dealer says 4/32" but you measured as 5/32"). Either way, I think they should have put on two new tires, but perhaps someone can shed some light on whether they were required to do so.
And no, I actually asked. The service guy told me that 5/32" was the legal limit and they did what they were told.
I'm not happy with my dealership right now.
I have new PS4 on order and also a meeting with the manager of the dealership later this week.
Yes, that is what they did.
Paul champagne (09-25-2018)
Received 2,192 Likes
Heres the real deal, if they had replaced the tires you would have paid for them. Just factored into what you paid for the car. So you got to use up 5/32nds remaining tires before you have to pay for tires. When ever quotes are sent to a preowned dept head they look at what they paid and what the costs are to sell. Sometimes they do little other times sent to auction, or all of it done. If there are no margins theyre not going to put alot of money in a preowned car. And then either way those costs are added into what the dealer has paid for the car and priced accordingly. So if you got new tires when you purchased the car you would have paid for them then. Only thng is you are paying for them later instead of sooner.
Don1954 (09-26-2018)
the CPO spec I just looked up is 4mm, or 5/32nds minimum. Them changing to less worn tires would be between you and the preowned dept Paul. When I used to do any preowned cars my standard was I recommended placement of any tires or brakes if they wouldn't make it to the first oil change at 5k. Obviously that was before the 5.0 and 15k oil changes but you get the idea. And we did that because as I always discussed with the preowned managers, I don't want our customers coming in for their first oil change after buying a car from us and being told they need tires and brakes. Then theyre in the office hot since in Houston the avg annual miles is 15k so theyre back in only a few months or generally after 1 or 2 car payments. As in all industries and personalities everything varies and is open to interpretation.
Paul champagne (09-26-2018)
In this particular case, the tires they gave me with the car, measure 5/32" in some places and 4/32" in other.
But I was assured by my salesman, before I closed the deal, that the car was in shape to do a 2500 miles road trip that I do twice a year. So that was the bar that I set, before the deal.
Brutal (09-26-2018)
So in short it doesnt matter where you measure, you measure the lowest spot
Carbuff2 (09-27-2018)
Brutal, I appreciate your expertise and comments, but from my perspective, unless there is significant wear inconsistency across the tread surface I will not avail myself of regular alignments to save a few miles wear on OEM tires. Most OEM tires cannot wear out too quickly for my liking, especially Pirellis and Continentals; I would never purchase either brand and only wish that tire brand was an option when ordering a vehicle.
Hello all,
In other words, the paperwork may have said "needs to be replaced" but the service manager decided "those are good to go" without him having to put money into them. Nobody and I mean NOBODY is going to go dig up a tire that has 1/32nd more tread than the tires they took off.
Paul champagne (09-27-2018)
4//32 vs. 5/32 is a measurement error so it seems obvious that they did not replace the tires prior to delivery to you.
Rickfreeland66
03-04-2018 05:14 AM
uh2
02-08-2017 07:19 PM
metalmarty
06-12-2009 08:27 PM
