Tires, tires, tires
SouthSider (06-09-2021)
I researched several tires that are recommended for Fs. Of course it depends on weather, usage (track or not). I chose the Continental ExtremeContact DWS (Dry Winter Snow). What's kind of neat is that there are wear bars on the tires, marked D W S and when the S (Snow) bar is worn off, then your driveablility in snow is decreased, then same with W (wet). The tires are quiet on just about all road surfaces here is North Central Wisconsin.
I know this has been asked a million time, but I'm looking to replace my P Zeros within the next two weeks. We have our first long distance road trip coming up and I'd like soem fresh shoes on the F-Type. We're in western Oklahoma so the winters do get cold and I'd prefer some tires that would work all year. The majority of our driving will be above 40F. Could I have your recommendations please!
If you do need something for snow and ice too, I recommend Michelin Pilot Alpin PA4s
#30
I had Michelin and Perelli. I went rogue and tried Lexani. I prefer tires with 4 wide rain grooves, but they make everything and they are great tires. I personally run 207’s in 18”.
#31
#33
I still have the original P Zero's on my car and they currently have 7200 miles them. During my recent state inspection at the dealership I was told that my rears still have a little life in them and my fronts have a lot of life (5K miles) left. Is there any thing wrong with replacing the rear tires with Michelin PS4's now and waiting until spring tp replace the fronts with the same Michelins? Will the two different brands at unequal wear levels cause any issues with handling, performance and comfort? Thanks.
#34
My 2-cents.
Portlander (06-10-2021)
#35
I took a risk 2 years ago on Delinte tires. I was very disappointed with other major brands. I bought Delinte and find them to be far superior in every respect with the exception of cornering. I'd give them a 4 out of 5 on cornering. In every other respect - excellent traction wet or dry, very low noise, great feel, steady at high speeds, extremely durable, good looks, they get 5 out of 5. See the latest D7 or even the newer D8 ... https://delintetires.com/tires/d7
#36
When I bought my X351, the summer tires were adequate but living in the mountains I will be changing them for Continental Extreme Contact DWS06 . Should get me May to October, they handle heavy snow in fall and spring but my Toyo Observes will be coming out again from 1st of November for sure.
I would also add that Toyo Tires are a Japanese not Chinese brand and Toyo USA are headquartered in California.
#37
I’ll add, I chose performance all season due to temperature range spec. Potential tire problems with high perf tire and below freezing temps.
I’ll also add, think twice (or more) about buying Chinese tires.
#38
#39
How does it mess with the TPMS sensors? Surely they're just looking at the air temps inside the tyre?
JgaXkr (06-17-2021)
#40
Michelin everytime, you will never consider P Zero again when you experience the difference
