tow hooks
#62
Hopefully Murphy sticks to his law, although nobody else seems to follow laws much anymore 😳
#63
STMPY When you get your new steering wheel in, if you don't mine I would like to take a look at it, since we're almost neighbors (I'm in Danville).
Wayne B.
#64
The following 2 users liked this post by Cambo:
JacksonvilleJag (05-30-2020),
Unhingd (05-29-2020)
#66
#67
However if one of us was to purchase the actual P7 member then the exact location could be shared with the community.
I will look into ordering the P7 cross member but I need confirmation that it is a direct bolt on.
#68
#69
Well, as all things P7 I will need an actual P7 vin to order the part. My dealer parts guy thinks it’s a bolt on but is not sure. I looked at my car but can only see the lower bolts. Could someone who has done the conversion verify that the member is bolted and there are no welds ?
Unhingd, WayneB ?
MM
Unhingd, WayneB ?
MM
#70
Unhingd, WayneB ?
MM
Unhingd, WayneB ?
MM
#71
Unhingd, WayneB ?
MM
Unhingd, WayneB ?
MM
WayneB
#72
Thanks,
Wayne B.
#73
There are three different front tow hooks, but nothing specific for Project 7, it's just overall VIN ranges of the car.
C2P1708 for up to VIN K22531 (this is the one from the XK/XKR, and the X250 XF)
T2H8295 for VIN K22532 to K50557
T2H33643 for VIN K50558-onward
The engineering part numbers suggest to me that the T2H8295 & T2H33643 are identical.
WayneB (06-02-2020)
#74
Not holding you responsible if you guess wrong, 95% convinced to just roll the dice and order regardless..
MM
#75
#76
Fred-type 400s (03-04-2021)
#78
Received 3,209 Likes
Looks correct to me and it even lists as compatible with 2014 and 2015 F-Type.
Maybe it'll fit/work, maybe it won't, maybe it's one you have already tried, maybe it really is a new thing.
#79
OK thank you. Then I will need to revise my request to zl1addons.
Then I need to attach a proper racing tow hook somehow as tow hooks both front and rear are required by the regulations in the Time Attack series I'll be running. I'm sure I can figure out a good location once I get my hands on the vehicle.
#80
I CAN attest that the front tow hook is absolutely critical to getting the car up on a flat bed tow truck. However, I did notice that despite cranking down hard when installing the hook, it became loose after a single load/unload trip up and down the flat bed. As such, I'd probably not recommend leaving it in place any longer than is necessary.
And from other threads here, I understand that the back hook should ONLY be used as a tie-down, and not for towing. Thanks, group!!!
Still, I'm curious as to whether the aftermarket tow hook for the XF works on the F-Type... including installation and removal. I look forward to finding out...
