TPMS Monitoring Fault
Hello experts,
I hope someone can help me with a problem I have been experiencing. The F-type has been idle for two months, and when I started it up yesterday, I found that the TPMS failure message was showing on the dashboard, and the light was blinking. I checked the tire pressure and confirmed that all tires were in good condition. I drove around, but the message and flashing light remained. I started the car again this morning, but the problem persisted.
I contacted the dealer, and they suggested that the TPMS sensors might need to be replaced, and if that doesn't solve the issue, it could be the module that would need to be replaced as well. That's an expensive exercise. Has anyone else experienced this problem and found a solution? Could anyone please let me know where the module is located and if it's worth replacing it first to see if it does resolve the issue? Thank you in advance for your help.
Michael211 (01-09-2024)
All tires are showing blank. I don't think it matters if the car is standing still, it should still read? Looks like a module problem then. Any idea where the module is located?
Great find, thanks so much for sharing! Looks like after installation it requires some software work. I’ll have to speak to the dealer to see if they would update the software should I decide to pick this work up. Should be a fun weekend project 😂
I'll try your suggested method, thanks! Did you have to reset the TPMS?
At risk of jinxing them, mine haven't missed a beat since I bought the car back in 2018. And to answer a previous question, yes, they work when stationary, I usually check mine every time I start the car.
I learnt something new from a dealer. I’ll need a tpms software update to make it all sync again, just putting in the part doesn’t do it. If you do that, they may be required to update other modules, including ECU, to make it all sync.
Has anyone had this experience before? My concern is the ECU update as I don’t want to give up the stock crackles.
A quick Google came up with mostly XK topics that used the older frequency sensors, but the consensus seemed to say that new sensors can be programmed...MAYBE simply by driving.
"If the sensor is replaced on a 'running' wheel, the new sensor identification will be learnt in the first 15 minutes of the vehicle is being driven."
The following 2 users liked this post by Carbuff2:
diablo2112 (01-16-2024),
JagFR (01-16-2024)
Closing the loop on this, I appreciate everyone’s help and input!
1) Module didn’t need replacement
2) All TPMS battery was fine
3) No software module update was needed
What fixed it? Good old fashioned hard battery reset (take terminals off, have both terminals touch each other or take a wrench to touch on for 5 secs, plug it all back in). Drove 50 miles and haven’t had the light come on and TPMS is synced reading the pressure.
Morale of the story - any time light comes on, try the hard reset before trying to replace part or do some software update.
The following 4 users liked this post by JagFR:
