Traction control after tire change
Hey all - I thought I would get your input on this. Back in March, I ended up with a bent wheel on my 2015 R. I decided to go with a set of wheels that I liked a little better than the stock Gyrodynes (replaced with Avante Garde M520R). Along with the wheel change, I also changed from the stock P-ZERO's to Continental ExtremeContact Sports. What's strange is that with the tire change, traction control seems to be freaking out a bit. Going anywhere near the throttle coming out of a corner in 2nd gear triggers traction control to cut power. Even in a straight line, if the road surface is a little pitted, traction control cuts power badly in 2nd and 3rd. The weird part is that I don't seem to be slipping at all when it kicks in. With the P-ZERO's, the 2nd -> 3rd shift would smoke the rear tires on full throttle. With the ExtremeContact Sports (if traction control doesn't kick on), that's not the case. With traction control off, they definitely seem to have more grip. They also seem to grip better in the corners than the worn out P-ZEROs.
Ideally, I'd like to not decrease traction control (TRAC or OFF) if I'm just driving a back road but I'm kind of at my wit's end with this. If I'm going to be turning the car to TRAC on a back road, then I'll want to get some track days in first to explore the limits of that.
Stock Gyrodyne 20" wheels
20x9 front / 20x10.5 rear
Stock Pirelli P-ZERO
255/35 R20
295/30 R20
Avante Garde M520R
20x9 front / 20x11 rear
255/35 R20
295/30 R20
255/35 R20
295/30 R20
Avante Garde M520R
255/35 R20
295/30 R20
JacksonvilleJag (07-03-2020)
Unhingd, roger that. I should have said curious why OP went with 11" in the back if he was going to stay with 295. Do you think that stretching the tire that far reduced torsional flex in the sidewall to the point it's causing his problems? I'm thinking in terms of drag racers that require sidewall flex to increase grip. On a different scale here, but probably still important. Thoughts?
WallaWalla
17
02-27-2012 11:45 AM
