Trap for young players - F-Type brakes
Received 3,209 Likes
Several years ago I upgraded the rear brakes on my F-Type from "performance" 326 mm to "super performance" 376 mm.
There is a thread or at least a series of posts about it around here somewhere but can I find it, no way!
Anyway the major hassle I had was getting brake fluid into/through the new calipers (bought new on Fleabay) and eventually I found that the holes in the calipers into which the brake line banjo bolts go had been plugged up with screws/plugs which were very difficult to see. Then when I tried to screw them out (hex/allen head around 3/8") they were stuck so hard I eventually rounded them off, and in the end I had to drill them out.
For years now I wondered about those blanking plugs and WTF were they doing in there, then lo and behold I just came across this vid by South Main Auto:
So apparently those blanking plugs are reasonably common and not some strange anomaly like I first thought, moral of the story beware if/when you go to fit new brake calipers to an F-Type!
Edit - forgot to add that when I first put the banjo bolts into those holes they did up nice and tight and everything seemed good to go, it's just that I could not get any brake fluid into the calipers no matter what I tried. It took several hours of head scratching and removal/refitting/inspection until I finally figured out what was going on, those plugs were buried way down deep and very difficult to see. So yes as Eric O surmised it would be quite possible to assume everything was good to go and then discover you had zero rear brakes!
The following 2 users liked this post by OzXFR:
uncheel (02-15-2023),
Valerie Stabenow (02-15-2023)
Nothing about them in the service manual which is not surprising as they don't exist on a new/working car!
"Nothing about them in the service manual which is not surprising as they don't exist on a new/working car!"
You don't need to know when you buy the car. But, when you SERVICE it...
This strikes me as something written by a technical writer - but not someone who had actually done the repair.
Thanks for this (and all your other helpful posts). Cheers.
Kaeghl
08-16-2023 12:40 PM
