It's definitely called Mechanism Cover and looks like the two piece items 2 and 3 rather than the one piece item 2 or item 11 in this JEPC extract. Being able to compare this with your vehicle will give you a better idea than I can get only by looking at the diagrams:
After that it starts to get complicated. VIN and colour are involved in determining the correct part numbers for these.
Jaguar are showing them as not available to order online. Dealer supplied only. This is likely to cause delay as I expect the JLR international distribution centre in Frankfurt, Germany is presently closed due to the pandemic. Good news is the cost is a lot less than I was expecting. Here in the UK item 1 is 35 UKP and item 2 is 29 UKP.
here are the parts. took multiple photos since the parts have multiple numbers
Unfortunately, none of those numbers look like a Jag part number. The actual part number on these 2 parts depends on the color of the plastic. You should find what you need on this parts explosion:https://www.suburbanautoparts.com/v-...and-components
Thanks, found something for cheap, if the color is different, I'm just gonna paint them or keep them as is
