Trunk won’t close while car is locked
I have a 2016 F-type coupe, and I’m trying to figure out the trunk. If I get out of the car and lock it, and then walk to the trunk and open it, it opens fine. However if I close the trunk, it does the super loud double beep, and then I have to manually lift the trunk back up. It refuses to lock it the car is locked.
Surely this isn’t normal??
Received 3,226 Likes
Locked car, open trunk, close trunk, all locked no sweat.
I have a 2016... If I get out of the car and lock it, and then walk to the trunk and open it, it opens fine. However if I close the trunk, it does the super loud double beep, and then I have to manually lift the trunk back up. It refuses to lock it the car is locked.
If your fob is out of range, can you open the trunk on your locked car?
This is just a W.A.G., but are you getting any indication (on the center display) that your bonnet (hood) is unlatched? I found out a few months ago that the car will not lock if the hood is open.
But can you lock the car by the door if there's a fob in the trunk? Seems that's what the OP is doing.
OP didn’t say he used the handle to lock. The door can be locked with the fob if the spare is in the trunk. I have not tried with the handle because I did not want to run into the house for the spare, but I suspect you are right that it wouldn’t work. I still vote for a spare in the trunk or a sensing receiver that’s misfiring.
Dan Bennett
09-13-2013 11:13 AM
