Tuning Question
I would caution you about tuning or even driving a V8 hard on 0W-20 as I think its an oil specifically made for econoboxes. Jag's own spec states, Ford Fuel Saver. The new GF-6 standard pushed by manufacturers tired of repairing cars in warranty proves that the original 0W/5W-20 provided inadequate engine protection at high RPM. Jag is the only manufacturer using it in 5.0L boosted GDI. Even Ford increases oil weight to 50 SAE when they add a SC to create the GT500.
We have anecdotal evidence showing all posted stock V8's dynos pulling timing around 5800 RPM. My car does that, see the red pulley-only run on the dyno above, but a switch to a more reasonable 0W-40 performance oil solved it. To each his own.
Tuning question from the mod enthusiasts on this site. Am considering going with the VAP tune WITHOUT the lower pulley in the next few months and my goal is to at least equal the 25 HP gain on the SVR and it appears that the VAP tune should accomplish that with around 40 HP gain to the rear wheels which is enough gain for my needs. After receiving the box in the mail should I find a local performance shop to properly install it seeing that electronics and technical aptitude is NOT one of my skill sets? There is a reputable business in the area that specializes in european makes for possible installation but I think their volume is more Porsche, BMW and Audi driven. From any members that have chosen this route, is the VAP tune a simple plug and play (on/off switch) and forget about it process for daily driving or does it require constant monitoring and trouble which I prefer not to deal with? My R is still under warranty until next September, as a courtesy should I check with my Jaguar service manager (appears to be mod friendly) first to make sure there are no issues with a simple tune or is it better to be low key and just disconnect/erase if I had to take it in for service? Thanks.
When the dealer connects to the car for service they will know that the system has been reprogrammed by a non-factory device even if you reflash to stock. The primary reason to flash back to stock is that if there are updates the dealer will be able to apply them. If you don't, make sure they do not apply any updates. If those updates affect the areas where the tune resides, you'll need to download the new file and email to VAP for a repeat of the process. I had to do that after the first service post tune. I also got an updated tune at my request to address throttle sensitivity issues seen in earlier revisions. I've got over 30k miles with the tune with no issues.
Best regards,
Jay
P.S. I seem to recall someone recommending hooking up a battery tender while the car is running and downloading and uploading the tune—which I am pretty sure I did— but I might be thinking of something else? I forget.
#28
There is only one and he is the best and I just had my center dashboard vent replaced last week because the leather was bubbling up due to it's time spent in the Alabama heat. Steve, my service date is coming up in July for the complimentary scheduled oil change (next to last one) and whatever else is included at the 3 year point, should I wait to do the tune after that visit just in case there are any required updates that may need to be accomplished? I currently have 15,000 miles on the car.
Portlander (05-10-2020)
#31
#33
No one knows this issue better then me, when I had a tune on one of my Shelby's I had a faulty oil pump. They tried to blame it on my tune. Long story short, ford rep was called and they paid for the work under warranty.
With that all said the tune HAS TO BE the DIRECT link to the problem. Two words - Magnuson-Moss!
#34
If you don't believe me, call Jag and tell them you've tuned your car, is the drive train warranty still good. The answer is no.
JgaXkr (05-10-2020)
#35
Connect the provided handheld device to the car and follow the instructions to download the original file. Disconnect.
Install the associated software on your PC. Connect the device to your PC and copy the file locally. Email VAP and attach the file.
Wait for a reply. It's the hard part, but turnaround is quick. I never expect it, but I've even gotten replies to queries on the weekend.
Save the file locally, connect the device again to the PC and upload the new file to the device.
Connect to the car and upload the new file. Some recommend connecting a charger to the car during this phase as you don't want the battery voltage to drop too far but I've done it with no charger every time but once.
Also worth noting is that the total number of miles on VAP tunes just on this forum is considerable and no one has noted any issues. I have over 30K miles on mine, although I haven't installed the pulley yet. Also not driving much these days because of the obvious public health restrictions or I'd have another couple of thousand.
#36
A flash tune (or a piggyback tune) can lead to questions about a drivetrain issue, but the tune would need to be proven to cause the issue to deny the claim. That's the law here in the United States.
#37
I doubt there is any further updating they'll do at the three year point, but it's up to you. The fill process is:
The difference is perhaps one of honesty. If you want to play, you should be prepared to pay. That said, your dealer sounds like more of a problem than JLR.
I'm not suggesting Racechip will not void your warranty, it does. But it's undetectable when removed versus a permanent code. The difference should be understood when selecting a tune.
Thats why reputable engine tuners offer a warranty that pays for damage caused by the tune, because the factory warranty will not pay.
#39
You are the one said the horse wasn't dead. Yes, everyone knows tuning voids your warranty. Yes, it's universally understood, or it should be.
That said, reputable tuners like Lingenfelter, Hennessy, Dinan, Racechip, Saleen, etc. offer various power train warranties primarily to fill the factory warranty gap which would otherwise discourage buying their tune. I am not associated with any of them.
#40
