turning off Eco start prevents car from moving
I have 2014 F-type base with 5K miles. This has happened twice - switched off Eco start/stop button while at a stop light. Drive light starts flashing and the car acts like it is in neutral - pressing accelerator races engine but car goes nowhere. First time it took around 25 seconds for the situation to clear and drive to engage normally but I don't know what I did or didn't do for this to fix. The second time I manually selected neutral then put it back in drive and then the drive light stopped flashing and the car drove normally. The owner's manual refers to the flashing light as drive being selected but not accepted. Accepted? What is that supposed to mean - the transmission gets to decide if it likes my choices? Dealer looked over car could find nothing wrong , no error codes etc. Suggested I just avoid using the Eco start/stop system, which I can do but I'd really like to know if anyone else has had this problem and/or has a fix. Thanks!
concertoed (01-11-2016)
I have a 2014 too. Disconnect the small battery in trunk - and the ECO thing is disabled permanently. I always found myself cursing a bit while disabling on the switch whenever it did the ECO stop on me, so I disabled permanently more than a year ago; no side-effects at all - recommended for anyone reaching for the switch every time the engine turns off at a stop
I've seen numbers published citing 2-3% savings on the EPA gas mileage protocol.
When I'm stuck in Washington, DC gridlock, which is pretty much every weekday, I leave eco-mode on all the time. I've learned to like it, and it's performed flawlessly for me.
I believe ECO will not stop the engine if the algorithm determines that inside cabin temperature cannot be maintained if the engine stops. ECO never shut off my engine when I took it out on a 95 degree day, top down either.
UntouchablesInc
05-21-2014 09:29 AM
dustedu5
01-02-2009 03:26 PM
