tyres for ftype coupe s
I don't believe Jaguar has a contract with Michelin, I have never seen a new Jag with Michelin tires.
Both the 19" standard and 20" optional tires for the 2015 V6S Coupe are Pirelli P-Zeros. It is unlikely they will change for 2016. Mine will arrive with the 19" Propeller wheel and I will immediately swap with a set of Mich PSSs mounted on 20" Black Diamond Cut Gyrodynes (not available as a factory option on the V6S)
Thus far (14-15 MYs), all the tires for each model have been the same on UK cars and those shipped to the US, Canada, Australia, and New Zealand. We've also had other countries represented here including Germany, Croatia, and UAE.
I found myself at the tyre shop today... Managed to dodge a bullet and have my rear right tyre repaired after they pulled a six inch nail out of it - a $30 repair instead of an $850 replacement tyre!
While I was waiting, I asked the guy what he would consider as a replacement, as I find the P Zeros skittish and hard to get the power to the ground.
Without hesitation, he said "Michelin Pilots", then added, "but they aren't cheap!"
Which I have never really understood. I always felt they were just a mediocre performance tire. Going to the track with them isn't exactly wise, as they tend to start crumbling at the outside edge when driven hard. I've always felt Dunlop Direzza ZIIs and Yokohama Neova AD08s were a better street/occasional track tire. Only issue is the limited sizes available.
Foosh (03-23-2015)
Chinese state-owned China National Chemical (ChemChina) is to buy Italian tyre maker Pirelli in a deal which values the firm at €7.1bn (£5.1bn).
The move is the latest in a string of takeovers in Italy by cash-rich Chinese buyers.
---> Oh boy, folks don't like our Pirelli's now .............
I guess I don't either unless things have changed. I've had both of the models you list above and was extremely impressed with both. The Yokos were the best sticking tires I've ever had on any car. I weight grip and predictability above all else. Tire noise and all other factors are way down the list.
Plus the only choices for those of us in the R Coupe are the P Zero and the PSS. Only two tires in OEM size for this car.
The PSS is not an extreme performance tire. It is a max performance tire (one notch below). The Yokos will give you more grip for sure and if you look at Tire Rack tests it has better lap times wet and dry. However ride quality, noise and overall lifespan for a road car user can't come close. You won't get 20-25k miles out of the Yokos. Many people have out of the PSS.
I'm running the same 20" OEM sizes on my base. As I said above, grip is the number one consideration for me, with everything else (including tire-wear) running far behind.
Yes, I understand that, and I mistakenly used the term "extreme," but I meant "max performance summer." Actually, there is another choice, ContiForce Contact, which is the most expensive of the three, and it is listed as "streetable and track performance," with a wear rating of 80 vs. 220 and 300 for the other two. It surprises me that there aren't options available from Dunlop and Yoko. I'm running the same 20" OEM sizes on my base. As I said above, grip is the number one consideration for me, with everything else (including tire-wear) running far behind.
Last night I was driving through heavy rain on single lane country roads with large puddles and the Michelin PSS did an amazing job of cutting through the puddles while maintaining grip. It was quite enjoyable in fact.
DuhCar (03-23-2015)
