Ultimate Carbon Fiber Wheel for your F-Type
For a paltry $10K a wheel you can have a custom set made out of carbon fiber cutting your wheel weight by as much as 50%. Of course if you hit a big pot hole you'd likely end up crying your eyes out.
Vitesse AuDessus releases ultralight carbon fiber sports car wheels
Lol so do mine but they are just bolt on trim pieces and as such they don't thrill me. Kind of embarrassing to explain the CF is just for looks.
I got the Blades primarily because they were forged whereas every other OEM rim offered in '14 was cast. I have cracked several cast aluminum rims over the years and really wanted the stronger forged rims to hopefully avoid going through that again.
Now there are forged Storms as well and those look a little better than the Blades IMHO. Hopefully I can get into a set of Storms so I can alternate the two.
Real, structural CF elements would be much more desirable than what jag did with the CF trim bolted to the spokes of the Blades IMHO.
Most cheap after-market stuff is "gravity cast" which the most susceptible to cracking and often doesn't meet the more rigorous wheel certification standards. As explained in the link below, there are more costly casting processes (primarily using higher pressures) that do meet the most rigorous OEM wheel certification standards.
http://www.tirerack.com/wheels/tech/....jsp?techid=90
While you are correct that forged wheels are the strongest, there are multiple methods for casting that result in widely varying strength.
One was a 19" VW Touareg wheel that had experienced no trauma. I noticed the crack when I was putting air in the tire. Had to spend $300 on a used replacement but at least it didn't disintigrate at high speed. One was a 17" Mercedes wheel that hit a pothole and cracked. In fact all four of the Mercedes rims eventually got replaced. One was a 17" Ford rim that impacted a curb at 10 mph and broke in half. The VW experience was particularly troubling as I did nothing to hurt the rim and it still cracked in the middle of a spoke. Those were all on my cars in the past 10 years. None of them were 180 mph cars.
One of Jaguar's cast wheels cracked during a long term test by one of the car magazines. They mentioned it was a problem others had reported as well. This, and the performance capability of the car, as well as my experience in the past, are the reasons why I sought out the forged rims on this car. If I can find the article I will cite it specifically.
I don't know if Jaguar's forged wheels are much better than their cast ones but I assume that to be the case.
