Uneven tire wear 2.0l
Received 3,259 Likes
About two weeks later I scrapped the OEM P-Zeros and fitted MPS4S. The P-Zeros both front and rear had similar wear to the OPs, very worn on the inner edges but heaps of tread in the middles and on the outer edges.
Since then the MPS4S have worn very evenly with maybe a tiny bit more wear on the inner edges than the outer edges. This is to be expected as previously noted due to the correct negative camber both front and rear.
I put the much more even wear down to 90% the wheel alignment and 10% the MPS4S.
I actually have a fresh pair of MPS4 sitting in my garage just waiting for my rims to arrive, I noticed the car sitting with a lot of camber when i picked it up recently from the original owner, but I had no idea was as bad as it was until I took it to the dealership for service. The p zeros are not that good either, so intended on buying new tires anyways.
Factory was not following its own spec.
Jsedita74
08-13-2011 08:08 AM
