Uneven Wear + Steering Wheel Vibrations
Hey guys, I love my FType. But can’t help but be annoyed by these problems I am currently experiencing.
Firstly, I have attached a photo of my rear tire. Clear as day, uneven wear. I have asked multiple people and took it to a shop, all say it’s due to my aftermarket rims (Non OEM) and how the car sits (Camber) since it’s a “sports/muscle car”.
I don’t buy it, I think there’s something more to it than just it being an after market rim? Like some ball joint? Wheel alignment? Wheel balance? Which by the way, I’ve taken it to three shops already, and they all say they “performed” the wheel balance and alignment and it was not that. I don’t know why I have my gut telling me they aren’t really fully looking for the problem, and just guessing.
Also, steering wheel… it shakes past 40mph. Need I mention, I have new rims, new tires, rear sway bar links, and wheel bearings have been replaced.
Based on your guys experience, what do you think is causing the steering wheel to shake? As well as the clear uneven wear on the tires? Thank you in advance.
Disclaimer
Tires are no more than 3 months old, also debating on switching back to OEM rims if the aftermarket rims is the problem. The only difference between the OEM rims and my aftermarket is the center bore size. AFTERMARKET is 72.6mm, OWM is like 53.4. I do have center hub rings installed to counter that.
What is this?
It is not uncommon for performance cars like the F-Type to be specified with toe-in and negative camber that causes the wear you pictured. This promotes good handling at speed (and, under high G-forces).
How many miles on those tires? How HARD do you drive it? (Some owners 'brag' about wearing out rears at less than 8,000 miles!)
That said, when we bought our F, the inside-rear was worn to the cords after 14K miles. Since having the car aligned, the wear is MUCH less. In fact, I'm becoming impatient because those P Zeros are not wearing out, even after another 15K.
You could tell your alignment shop that your concern is tire wear; a GOOD shop can set the geometry at the edge of factory specifications so as to minimize the wear. (NOT eliminate)
Assuming your hub-centering rings are properly sized to the 53.4 mm of the original, I'd look to having your front tires Road Force Balanced. Perhaps have the INSIDE of the rims measured for run-out. (Some rims are easier to bend than others, especially if they are a wider width.)
Good Luck!
Good Luck!
SirJag
07-09-2012 06:15 PM
