upper oil pan gasket?
my question is about the f type which is a moot point as its the same motor in an xf, so i'll post there if no one here knows.
edit: just realised the xf details had been put into my sig, i just updated that, sorry for the confusion
I haven't looked up the parts or checked diagrams, but would not be surprised if there is no gasket and that an anaerobic sealant is called for, e.g. Loxseal.
Never came across an engine without an oil pan gasket (either lower or upper). Learn something new every day.
As noted, I didn't look anything up. I haven't seen it on a car yet and if the pan is stamped steel it'd surely need a gasket, but on motorcycles the machined cast aluminum faces seem to be getting sealer instead.
Carbuff2 (03-24-2022)
Just checked the repair manual (should have done that first). Apparently there is no gasket used only Loctite 5901G (RTV).
