Upper pulley swap on 5.0l SC
If it was the best choice, a manufacturer would use it too instead of steel...
Hi Stuart,
I don't doubt your information about SVR and R having the same boost limit on their standard tune, but am curious what leads to the 26PS power increase on the SVR at the same maximum power revs of 6500rpm ?
This thread has the rest of the answers you are seeking; basically upper pulley doesn't do much compared to a lower pulley and neither will increase peak power without a tune. Even with a tune the lower pulley only adds maybe 40 - 45hp max....the SC pulley less than half that...
Dave
Without any doubt ECU flashing should be your first upgrade. Consider the other ones as add-ons for later. Of course we work with Viezu and we sell those tunes. The 550hp base R goes straight to 600HP with a terrific increase of torque along the entire rev range.The best $735.00 you can spend on your car.
Jireh777 (02-21-2021)
#30
Our world-leading software is available to forum members at a 10% discount using the coupon code JAGFORUMS at $895. 100% custom tailored to your specifications & preferences, up to 5 modified files and no charge for re-tunes if the dealer updates your software.
Only the best!
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Itismejoshy (02-01-2018)
#31
Stuart a 60.5mm pulley (I guess you did your homework on our work) can be fitted without shaving the snout on most engines, few require minor grinding of high spots. It's just not a cheap aluminum pulley. As a matter of fact Eaton strongly discourages using aluminum for the supercharger pulley due to the fact that it has greater slippage over steel (of course there are surface treatments for the pulley if one wants). The only reason to promote and sell an aluminum pulley is for easy of installation (heat and slip on) while a steel one requires the removal of the snout and pressing.
The facts are clearly verified and published, I am not going to spell out how and what we do. Anyone can Google "Viezu Predator". And yes... there is another more aggressive tune for the upper pulley swap. Stuart, I will not engage in an encore with you as I would like to keep everything civilized. The 650hp fact are all out there and verified.
All the dyno sheets and videos show a base run of around 509bhp and then claim 640-650bhp, nowhere was I able to find any "verified" data claiming an estimated 650bhp(lots of media coverage but zero data). Sure I may be looking in the wrong place, so it would be nice for you to post publicly where this information is located(on a site or another forum by members?)..this way the clients and members can view.
Btw, not fully sure how Viezu is rating the stock crank power at 509ish BHP on an F-Type R(550PS), I've yet to find a Jaguar F-Type that's underrated. If Viezu is getting 509BHP stock, that just means their dynoing with the drive cycles learned on the stock file and then running the mod without drive cycles..that would be claiming false results because if that stock file had the drive cycles wiped, it would net high number without even changing any maps or parameters? Being your a vendor for Viezu, can you elaborate on this please?
Here's a Viezu vid showing what's questioned:
__________________
________________
Christopher Edgett
Technical Director
Velocity Automotive Performance Limited
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
Office Tel: (250) 485-5126
www.VelocityAP.com
Tuning@VelocityAP.com
________________
Christopher Edgett
Technical Director
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
www.VelocityAP.com
#32
#33
Really we should be talking about horsepower based on quarter mile MPH/weight comparisons...
#34
+1. The most reliable results are achieved from hub driven load bearing dynos rather than rolling roads or inertial dynos, but as you mention, calibration and environmental conditions skew the results. That said, even the quarter mile results are mightily affected by surface and environmental conditions. The real value of any of these methodologies is for side-to-side comparison.
#35
That's an easy one; the tune is by FAR the best $$$/hp choice. On the V8 you can chose up to just over 600 hp (+100 crank hp from the stock V8S levels) with no hardware changes whatsoever. The VAP tune I have (which I haven't installed yet - long story) can be set at 550/575/605 depending on what you want.
Dave
Dave
#36
Though I haven't installed mine yet, I plan on sticking with the 575hp SVR/P7 tune.
Remember that the ONLY difference between the 495/550/575 factory rated outputs is software.
Dave
#37
Dave
#38
Not optimistic at all; VAP has sold many forum members this tune with no issues. The JVIII issue was a completely different product.
Dave
Dave
#39
Dave
Dave
Don't forget the Project 8 as I believe that car is 600PS and again is same hardware as the others, but might be wrong.
#40
The base V8S cars, have exactly the same engine as the Project 8. There's 100BHP there it's just being held back. Same engine in the 'R', same one in the Project 7 & SVR.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
homerlikebeer (07-05-2023)
