V6 F-Type modding?
#41
I would like to ask a couple novice questions:
1. Has anyone had this done the lower pulley at a shop vs a DIY? If so, what is expected cost? Is there a recommended place in the Philly, PA area?
2. Can you do this pulley without a tune or is that bassackwards?
3. If yes to #2, does JLR care about a new pulley from a CPO perspective? I assume they would notice??
2. Tune without pulley ok, I would assume most would agree with me, no on the pulley only without tune. May not hurt but will not have positive impact. Others can provide more details on that.
3. Mine has been to the dealer for normal maintenance etc. and they have never mentioned a thing. Also note, I also revert to stock ECU maps first. I think that is must, but others can chime in.
#42
So you're driving the car with the "stock" tune and VAP pulley to and from the dealership during this time. I am assuming that as long as you are driving it normal and not ripping on it, that there is no issue doing this yeah?
#43
I also will say I rather dislike driving it that way, and upon retrieving the car the last time it was in (canister recall), I remapped right there in the parking lot.
FR500GT (01-05-2018)
#44
#45
ok, so let me get this straight...
If you do the tune and pulley and decide to load the stock tune before servicing at JLR without reverting to the stock pulley you are putting your vehicle at risk? What if the dealer needs to take the car on a spirited ride to diagnose something and you have the stock tune and VAP pulley???
#46
Reverting back to the stock ECU mapping is just so the dealer does not brick your ECU with an SW update.
Leaving the pulley on has no negative impact, its just wasted increase in boost. Perhaps think about it this way, without the VAP ECU maps the car ignores the pulley's impact on the SC.
I'm certain someone else can confirm my statements.
#47
OK, that makes sense and eases my mind some. I, likely incorrectly, interpreted the prior post as if you revert to base tune and keep the pulley on you better drive conservatively or it could screw something up.
I do get why to revert to the base tune when getting serviced so they don't brick the ECU unknowingly.
#48
#49
Also very interested to hear from those of you above who mentioned the springs. Did it improve both the ride and handling?
#50
I love the summary by Stuart on the best bang for $ on the mods. With a V6S, looks like the tune and lower pulley are the two mods to do to get the most out of the performance. I saw the detailed DIY that was rated a 5 out of 10 for difficulty. Without a lift for me, that puts it to about a 9 out of 10 for difficulty.
#51
I mean I’m the only person here who’s had such a problem; supercharger replacement and valvetrain damage due to excessive tolerances. The superchargers failing is not uncommon for either engine (they are different superchargers) and I’ve been told the valvetrain is one of the weaker parts of these motors when it comes to modifying. But I am not convinced my modifications had anything to do with it. The supercharger was more or less needlessly replaced and a ECU tune/more boost doesn’t just cause excessive valve lash immediately after their inception. I imagine this was just an issue with the engine that occurred over time; it may not have been built as well as it could have.
I will say I don’t feel that these engines are the most reliable out there, so be aware of that. It’s no Toyota engine that is all but guaranteed to last for hundreds of thousands of miles if maintained properly.
#52
Did I read somewhere that the AJ126 engine was/is designed and/or built by Ford?
I also recall reading JLR was going to stop having Ford build them circa 2020, or perhaps it was just not at the current plant.
Or is there some chance the V6/8 will go away for that I4 only model. That actually felt odd just typing it.
Don't want to go off on much of a tangent.... but that is what thought surfaced.
#53
Received 3,209 Likes
I can't comment on question 3, other than to say that my warranty expires on the same day I'm having the pulley fitted so it won't make any difference to me if JLR did notice the pulley, and I don't intend to ever take the car back to a JLR dealership anyway.
#54
I also didn't have the lift or the inclination so my local performance shop boys did it. About an hour's labour charge as I recall.
I think Chris from VAP told me that with the lower pulley fitted but the stock tune (like when driving to the dealer for service) spirited driving may throw a CEL briefly but should clear when the tune is restored as the OEM tune gets puzzled by the extra boost.
#55
good info guys...I assume the pully installation aligning to the last day of warranty is not a coincidence? I'm interested to hear how the incremental performance increase is.
unhinged - you are one of the closer experts geographically, I may be taking a drive to MD to leverage your performance contacts and buy you lunch when I finally pull the trigger on the tune and pulley. I'm a nervous nelle so wont be doing that work until Im closer to the end of my CPO.
#56
The other reason I have explained before - if something major were to go wrong with the engine, unconnected to any tune or pulley install, while it was still under warranty, then the obvious presence of the larger pulley would probably cause JLR to reject any warranty claim, so better to delay the pulley install until after the warranty has expired (which was only a two month wait in my case so no biggie).
Last but not least, I will remove the under-trays (and refit them later) before taking the car in to have the pulley installed which should save a bit in labour cost.
#57
Looking forward to meeting up with you.
#58
my incremental comment was purely based upon the fact that he already had the tune and is now adding the pulley. So I assumed approx half of the 70 horses seemed a little more incremental than the whole shebang. Meaning, he is probably used to the tunes boost in performance by now and Im wondering how adding the pulley after being accustom to the tune will feel.
Combined 70hp is huge and I cant wait to do it myself....but my wife did ask me a fair question last night, "what roads around here can you even use the horsepower/speed the car has now"
Speaking of wasted power, I changed insurance carriers and they recommended these plug in driving recorders for better rates. Anyone used them in their Ftypes or any other cars?
#59
#60
